Bootloader Internals
Hey,
Does anyone have any links to good documentation for understanding the bootloader that comes with an UNO? I would really like to understand as much as possible about the bootloader, but I'm having trouble finding good sources of information.
Ideally I would like to be able to modify/optimize the bootloader for my own purposes. At a minimum it will make me a better Arduino developer to undersand how it all works.
Thanks. -Mitch
Well the source code files for all the standard arduino bootloaders are included in the IDE distrubution. Here is where they are located on my PC:
C:\Documents and Settings\Primary Windows User\My Documents\My Programs\Arduino\arduino-1.0\hardware\arduino\bootloaders
Wow, cool...that helps.
One more question before I dig in...which one do I look at for an UNO (Atmega328)? Can you provide some insight into the various subdirectories?
  • atmega?
  • atmega8?
  • bt
  • lilypad
  • optiboot
  • stk500v2
I will dig into 'atmega' in the mean time.
Thanks again. -Mitch
The Uno normally comes with Optiboot loaded.
Bootloader tutorial/FAQ: http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=79206 Atmel has several documents describing bootloaders and the programmer communication protocols they use to talk to their hosts...
Optiboot is the current bootloader for Uno-like Arduinos. STK500v2 is the current bootloader for MEGA-like devices. It is larger than the other bootloaders and supports uploads of sketchs larger than 128k of memory (at least in theory.)
