Okay so we had ordered few samples of ATmega 328P-AU from Aliexpress, China but got ATmega 328PU-PH.
I tried searching for this online but didn't get any resource or mention in the datasheet.
Just for curiosity, I hooked it up in the circuit and tried boot-loading it using a Nano, it didn't work. Just a few blinks on Digital IO 13 when I power it up.
Now before I open a wrong product claim, wanted to ask :
Q) Is it an original chip or just a fake as there is no part no. available with the same name/package?
Alas, chip labeling frequently isn't an exact match for actual part numbers, so I'm not sure that non-match labels mean anything...
Would that be a circuit and bootloading setup/process that is "known to work" with real ATmega328p chips? Or a custom-designed new board, or something you just threw together? The -AU should be an SMT chip, right? Are the chips you got SMT as well, or DIPs? There is a lot that can go wrong in the "hook it up and program it" process (especially with SMT chips.)
There are now some chips from china that are "somewhat" Atmel compatible - the LGT8F328 from Logic Green. I'm not sure if they use the same ISP programming method as Atmel chips, though.
I have corrupted the bootloader in LGT8F328P LQFP32 miniEVB probably
I have one more functional item.
Please, let me know how to upload the bootloader again?
Mariusz
