Hi everyone,
I'm working on a custom board for some IC testing and have an ATmega328p to control it all. I've been trying to install the arduino bootloader to simplify the programming steps however after a day of trying I can't get it working.
I'm using the ArduinoISP method wit;
Arduino Mega 2560 with the ICSP pins going to MISO, MOSI, SCK, GND, 5V and Reset going to pin 10.
But the error i get is
avrdude: stk500_getsync(): not in sync: resp=0x00
Verbose outputs gives
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM13
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: erasing chip
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0xFD"
avrdude: writing efuse (1 bytes):
Writing | ***failed;
################################################## | 100% 0.07s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xFD:
avrdude: load data efuse data from input file 0xFD:
avrdude: input file 0xFD contains 1 bytes
avrdude: reading on-chip efuse data:
Error while burning bootloader.
avrdude: verification error, first mismatch at byte 0x0000
0xfe != 0xfd
avrdude: verification error; content mismatch
avrdude done. Thank you.
I have also tried the Gammon Programming Tool with the same setup, getting the following results
Atmega chip programmer.
Written by Nick Gammon.
Version 1.38
Compiled on May 2 2018 at 17:28:53 with Arduino IDE 10805.
Attempting to enter ICSP programming mode ...
Entered programming mode OK.
Signature = 0x1E 0x95 0x0F
Processor = ATmega328P
Flash memory size = 32768 bytes.
LFuse = 0xFF
HFuse = 0xD9
EFuse = 0xFD
Lock byte = 0xFF
Clock calibration = 0xA9
Type 'L' to use Lilypad (8 MHz) loader, or 'U' for Uno (16 MHz) loader ...
Using Uno Optiboot 16 MHz loader.
Bootloader address = 0x7E00
Bootloader length = 512 bytes.
Type 'Q' to quit, 'V' to verify, or 'G' to program the chip with the bootloader ...
Erasing chip ...
Writing bootloader ...
Committing page starting at 0x7E00
Committing page starting at 0x7E80
Committing page starting at 0x7F00
Committing page starting at 0x7F80
Written.
Verifying ...
Verification error at address 7E00. Got: 0x00 Expected: 0x11
Verification error at address 7E01. Got: 0x00 Expected: 0x24
Verification error at address 7E02. Got: 0x01 Expected: 0x84
Verification error at address 7E03. Got: 0x3F Expected: 0xB7
Verification error at address 7E04. Got: 0x02 Expected: 0x14
Verification error at address 7E05. Got: 0x3F Expected: 0xBE
Verification error at address 7E06. Got: 0x03 Expected: 0x81
Verification error at address 7E07. Got: 0x3F Expected: 0xFF
Verification error at address 7E08. Got: 0x04 Expected: 0xF0
Verification error at address 7E09. Got: 0x3F Expected: 0xD0
Verification error at address 7E0A. Got: 0x05 Expected: 0x85
Verification error at address 7E0B. Got: 0x3F Expected: 0xE0
Verification error at address 7E0C. Got: 0x06 Expected: 0x80
Verification error at address 7E0D. Got: 0x3F Expected: 0x93
Verification error at address 7E0E. Got: 0x07 Expected: 0x81
Verification error at address 7E0F. Got: 0x3F Expected: 0x00
Verification error at address 7E10. Got: 0x08 Expected: 0x82
Verification error at address 7E11. Got: 0x3F Expected: 0xE0
Verification error at address 7E12. Got: 0x09 Expected: 0x80
Verification error at address 7E13. Got: 0x3F Expected: 0x93
Verification error at address 7E14. Got: 0x0A Expected: 0xC0
The options pressed were U for Uno and G for program.
If this is run multiple times in succession then the device signature changes every so often, becoming an unrecognized device. I have two custom boards, and have the same errors on both of them.
I had thought the 328p's were burnt in the assembly but if the signature is read correctly (most of the time) then I'm not sure what the problem is.
Anyone seen this before? Got any solutions?
Cheers
