Bootloader with Atmel-ICE
I am trying to load the Bootloader to a ATTiny1634 (Optiboot) from the ATTinyCore by SpenceKonde with the Atmel-ICE programmer.
I have tried this with both 3.3V and 5V.
I receive the following error:
Arduino: 1.8.19 (Windows 10), Board: "ATtiny1634 (Optiboot), UART0 (Serial), Enabled, 8 MHz (external), B.O.D. Enabled (1.8v), B.O.D. Disabled (saves power), B.O.D. Disabled (saves power), Enabled, Port A (pins 1~8)"
C:\Users\Robert\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18/bin/avrdude -CC:\Users\Robert\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2/avrdude.conf -v -pattiny1634 -catmelice_isp -Pusb -e -Uefuse:w:0b11111110:m -Uhfuse:w:0b11011110:m -Ulfuse:w:0xED:m -Uflash:w:C:\Users\Robert\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2/bootloaders/optiboot/optiboot_attiny1634_8000000L.hex:i
avrdude: Version 6.3-20201216
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Robert\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : atmelice_isp
         Setting bit clk period        : 5.0
avrdude: Found CMSIS-DAP compliant device, using EDBG protocol
         AVR Part                      : ATtiny1634
         Chip Erase delay              : 15000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     5     4    0 no        256    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     16384   32    512  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : JTAG3_ISP
         Description     : Atmel-ICE (ARM/AVR) in ISP mode
         Vtarget         : 5.4 V
         SCK period      : 5.00 us
avrdude: Short read, read only 0 out of 512 bytes
avrdude: jtag3_edbg_recv(): Unexpected response 0xd0
avrdude: stk500v2_jtag3_recv(): error in jtagmkII_recv()
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: jtag3_edbg_send(): Unexpected response 0x81, 0x11
avrdude: jtag3_edbg_recv(): Unexpected response 0x80
avrdude: jtag3_edbg_send(): Unexpected response 0x5c, 0x01
################avrdude: Short read, read only 0 out of 512 bytes
avrdude: jtag3_edbg_send(): Unexpected response 0x4e, 0xb9
################################## | 100% 1.46s
avrdude: Device signature = 0x303030
avrdude: Expected signature for ATtiny1634 is 1E 94 12
         Double check chip, or use -F to override this check.
avrdude: jtag3_edbg_send(): Unexpected response 0x31, 0x00
avrdude: jtag3_edbg_send(): Unexpected response 0x01, 0x00
avrdude: jtag3_edbg_send(): Unexpected response 0x74, 0xf7
avrdude: jtag3_edbg_signoff(): failed to read from serial port (0)
avrdude done.  Thank you.
Error while burning bootloader.
It looks like you don't select correct programmer.
