HI, this is a simple case of a new board, amtel 328, nothing clever, there is a 'serial port' the same as the pro mini (16mhz clock 5v version). I can program the board via 'unpload using a programmer' from arduino ide 2.1.1, (Atmel ICE)
I have tested the serial interface and can send and recieve data over the serial interface (tx/rx pins on the 328) I know the DTR is wired correctlky and triggers a reset of the 328 when grounded.
attemps to burn a bootloader from arduino IDE fail with an error:
avrdude: verification error, first mismatch at byte 0x0000
0xff != 0x0f
avrdude: verification error; content mismatch
I can however burn and verify the bootloader using Atmel studio, then setting the fuses to : ext 0xFD, high 0xDE, low 0xFF, I have seen others have 0x05 for extended, but with atmel studio 5 this cannot be set. So BOD=2v7
Now if I try and program via the serial interface from the Arduino IDE I get an error- port cannot be opened. even if I power off/on the system I get the same error
Help please!
Thanks Ian
I have burned the optiboot_atmel328.hex bootloader via
