Have error code " avrdude: Expected signature for ATmega 328p is 1E 95 0F Double check chip .or use -F to over ride see attached
the chip stamp has AMEL 3547D Atmega 328 U 2049HRR ( I order a ATmega 328 PU but 328 u -this is what they sent me ))
NOT SURE WHAT TO DO -Need GUIDANCE
and if I do a -F where do I insert it ?
I followed the directions in the tutorial , use the schematic , Wiring is okay , communication okay but this error
I noticed that the chip in mu UNO board is AMEL 35473D Atmega 328P U 2025SJJ
Is this causing a issue ?
Just ignore -F, it doesn't help.
Switch on the more detailed info for uploading in the preferences.
Check the circuit again.
It can be difference in the MCU. There are various 328 on the market and 328P differs in signature from 328 (1E9514), it could be the problem. Check it according the datasheet.
Different packages , versions, temperature ranges etc if the chip report back different device signatures. If that number is not recognised by the IDE it throws an error .
You can add your new signature , this might help :
You have cut off the most important part of the error message. The most common causes of this error can not be fixed by -F or by editing avrdude.conf, so please don't waste your time and potentially mess up your toolchain by going down either of those rabbit holes until we have completed the minimal initial investigation.
Please do this:
- Tools > Burn Bootloader
- After the Burn Bootloader process fails, you'll see a button on the right side of the orange bar: "Copy error messages". Click that button.
- In a forum reply here, click on the reply field.
- Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
- Press "Ctrl + V". This will paste the Burn Bootloader output between the code tags.
- Move the cursor outside of the code tags before you add any additional text to your reply.
This procedure is what you should always follow when asking for help with error or warning messages on the forum. Posting screenshots of text is not very helpful.
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
Error while burning bootloader.
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
option enabled in File -> Preferences.
First thanks for letting me know how to copy the error to the form Here is the error The data sheet given is ATmega48PA/88PA?168P/328P from ATMEL 8 bit AVR Microcontroller with 4/8/16/32K Bytes In System Programmable flash
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM8 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM8
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9514 (probably m328)
avrdude done. Thank you.
I included all the complier warnings when back to preferences included " all "
OK, very good. So it is recognizing the signature correctly, rather than the thing that happens 99% of the time where the signature check fails because the chip is not recognized at all.
My recommended solution is to use MiniCore:
After installing it, you'll be able to select Tools > Board > MiniCore > ATmega328, then Tools > Variant > 328 / 328A. After that, you'll have no problems with the signature because the Arduino IDE will be configured for the chip you have.
Because the ATmega328 and the ATmega328P are identical in every way that matters for these purposes, the other options will work as well: running avrdude from the command line with the -F flag to cause it to ignore the signature mismatch, or editing avrdude.conf as @hammy recommended. Those are slightly more complex than the MiniCore approach, but not by much.
Looks like you got an ATmega328-PU instead of an ATmega328P-PU. The 'P' after 328 is important.
One way to work around the problem is to find a 'board' declaration that uses the 328. The declaration for the UNO in boards.txt is:
uno.name=Arduino Uno
uno.vid.0=0x2341
uno.pid.0=0x0043
uno.vid.1=0x2341
uno.pid.1=0x0001
uno.vid.2=0x2A03
uno.pid.2=0x0043
uno.vid.3=0x2341
uno.pid.3=0x0243
uno.upload.tool=avrdude
uno.upload.protocol=arduino
uno.upload.maximum_size=32256
uno.upload.maximum_data_size=2048
uno.upload.speed=115200
uno.bootloader.tool=avrdude
uno.bootloader.low_fuses=0xFF
uno.bootloader.high_fuses=0xDE
uno.bootloader.extended_fuses=0xFD
uno.bootloader.unlock_bits=0x3F
uno.bootloader.lock_bits=0x0F
uno.bootloader.file=optiboot/optiboot_atmega328.hex
uno.build.mcu=atmega328p
uno.build.f_cpu=16000000L
uno.build.board=AVR_UNO
uno.build.core=arduino
uno.build.variant=standard
It may work to create a file 'hardware/breadboard/boards.txt' in your sketch folder with the following content:
ATmega328.name=ATmega328 on a Breadboard
ATmega328.vid.0=0x2341
ATmega328.pid.0=0x0043
ATmega328.vid.1=0x2341
ATmega328.pid.1=0x0001
ATmega328.vid.2=0x2A03
ATmega328.pid.2=0x0043
ATmega328.vid.3=0x2341
ATmega328.pid.3=0x0243
ATmega328.upload.tool=avrdude
ATmega328.upload.protocol=arduino
ATmega328.upload.maximum_size=32256
ATmega328.upload.maximum_data_size=2048
ATmega328.upload.speed=115200
ATmega328.bootloader.tool=avrdude
ATmega328.bootloader.low_fuses=0xFF
ATmega328.bootloader.high_fuses=0xDE
ATmega328.bootloader.extended_fuses=0xFD
ATmega328.bootloader.unlock_bits=0x3F
ATmega328.bootloader.lock_bits=0x0F
ATmega328.bootloader.file=optiboot/optiboot_atmega328.hex
ATmega328.build.mcu=atmega328
ATmega328.build.f_cpu=16000000L
ATmega328.build.board=AVR_UNO
ATmega328.build.core=arduino
ATmega328.build.variant=standard
The only change is from mcu=atmega328p to mcu=atmega328. If you select this board type before burning a bootloader it should expect a 328 instead of a 328P.
Arduino: 1.8.13 (Windows 10), Board: "ATmega328, Yes (UART0), EEPROM retained, 328 / 328A, BOD 2.7V, LTO disabled, External 16 MHz"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\MiniCore-master\avr/avrdude.conf -v -patmega328 -cstk500v1 -PCOM8 -b19200 -e -Ulock:w:0x3f:m -Uefuse:w:0b11111101:m -Uhfuse:w:0b11010110:m -Ulfuse:w:0b11110111:m
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\MiniCore-master\avr/avrdude.conf"
Using Port : COM8
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Device signature = 0x000000 (retrying)
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
Now it does not seem to recognize the chip I'm going to re order make sure I get ATMEGA328P-PU
thanks for you help Oh I did check all my connections
I bought some 328 (no P) chips by mistake and using the, previously mentioned, MiniCore make it a breeze to bootload them. Besides, if you bootload to 8MHz internal you get 2 more GPIO pins.
aedford1551:
This is the signature error we see more often.
Carefully check the wiring between the programmer and target.
I see a crystal in the circuit diagram on the tutorial you are following. Do you have one on your circuit? Make sure it's wired correctly.
