BootLoading Atmage128 using arduino as isp problem
evening arduino guru’s
couple of weeks ago i planned to bootload a newley purchased atmega128 64pin chip after soldering it on a pcb and conected the basic circuit with external 16Mhz crystal and taking in consideration the spi programming pins…yet i failed to succeed with the uploading bootloader process < attached dumb file>
for the bootloader used i followed the link to make it http://arduinoexplained.blogspot.ca/2012/03/how-arduino-download-programs-to-board.html
when i use the avrdude through terminal the chip is recognized without errors verifiyng the correct signature (good sign that my circuit is ok i guess :roll_eyes: )
been looking for answer for this issue and i am nearly goin nuts ! yes there might be plenty of wonderful chips out there but i lacked the experience when i bought it back then now i have no idea what to do with it
dumb (35.2 KB)
BootLoading Atmage128 ...
You mean an Atmega1280?
I think my sketch on this page will upload a 1280 bootloader:
http://www.gammon.com.au/forum/?id=11635
(Near the end of the post it mentions it).
no i mean Atmega128 here's the data sheet:http://pdf1.alldatasheet.com/datasheet-pdf/view/392232/ATMEL/ATMEGA128A-AU.html i dont know if your post gonna help but i'll have a look and tell you thanks for the reply though ;)
