Bootloading ATMega2560V
Hi, I am stumped I am trying to program a 2560V on a custom PCB and getting errors from avrdude, I am not sure if it is a design error on my PCB or something wrong. So if someone could confirm everything is ok I would be very grateful.
https://www.dropbox.com/s/0ld57kyslr4ajhs/Schematic.pdf
elvyn-249-88:~ jonny_flowers$ avrdude -p m2560 -c avrispmkii -P usb -B 1 -vvv
avrdude: Version 5.3.1.osxintelhack, compiled on Feb  1 2007 at 22:30:12
         System wide configuration file is "/usr/local/etc/avrdude.conf"
         User configuration file is "/Users/jonny_flowers/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port            : usb
         Using Programmer      : avrispmkii
         Setting bit clk period: 1.0
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200112693
Using p = 1.00 us for SCK (param = 3)
         AVR Part              : ATMEGA2560
         Chip Erase delay      : 9000 us
         PAGEL                 : PD7
         BS2                   : PA0
         RESET disposition     : dedicated
         RETRY pulse           : SCK
         serial program mode   : yes
         parallel program mode : yes
         Timeout               : 200
         StabDelay             : 100
         CmdexeDelay           : 25
         SyncLoops             : 32
         ByteDelay             : 0
         PollIndex             : 3
         PollValue             : 0x53
         Memory Detail         :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65     6   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel AVR ISP mkII
         Programmer Model: AVRISP mkII
         Hardware Version: 1
         Firmware Version: 1.10
         Vtarget         : 3.4 V
         SCK period      : 1.00 us
avrdude: stk500v2_command(): command failed
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
You seem to have a 12-pin ICSP connector and I'm only familiar with 6-pin and 10-pin versions.
It is actually a socket for a Wiz820io that I am using for programming as well.
