bootloading raw 328
Using Uno with 328-PU DIP package and 6U2 as ISP, loading to raw 328P-AU TQFP package on PCB.
loaded arduinoISP sketch, pin 10 to reset, pin 11 to PB3, pin 12 to PB4, pin 13 to SCK. First time around I get "not in sync", after that I get "programmer not responding". Cut power nd restart, and get not in sync again.
using arduino 022
I shorted reset to +5V on the SPI arduino, now I get
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
disconnected the power over RJ-45 and fed it power from the FTDI cable instead- so FTDI and SPI are connected at same time, but FTDI is strictly for power.
first try was not in sync
second try was yikes error
third try was programmer not responding
I put a 147 ohm in place of the shorted reset, still got the yikes error
Shut down the Arduino IDE. In the preferences.txt file set "upload.verbose=true". Start the IDE. Try the Burn Bootloader again and you should get verbose output that will tell you more. If the device signature being read is all 0's then you probably have a bad connection or a bad clock on your target system.
First time:
avrdude: Device signature = 0x000000
this check.
avrdude: Send: Q [51] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
avrdude done. Thank you.
*sigh
tried again, got this
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P/dev/tty.usbmodem3d11 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude: Version 5.4-arduino, compiled on Oct 9 2007 at 11:20:31
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/Steve/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbmodem3d11
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
Third time:
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 5 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81] [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82] [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98] [20]
avrdude: Recv: . [00]
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
avrdude: Send: A [41] . [84] [20]
avrdude: Send: A [41] . [85] [20]
avrdude: Send: A [41] . [86] [20]
avrdude: Send: A [41] . [87] [20]
avrdude: Send: A [41] . [89] [20]
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00] [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00] [20]
avrdude: Send: P [50] [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: u [75] [20]
avrdude: Recv: . [14] . [ff] . [ff] . [ff] . [10]
################################################## | 100% 0.04s
avrdude: Device signature = 0xffffff
this check.
just tried with arduino 1.0
/Users/Steve/Downloads/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Users/Steve/Downloads/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P/dev/tty.usbmodem3d11 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Users/Steve/Downloads/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
avrdude: stk500_getsync(): not in sync: resp=0x10
It works, I have used the ArduinoISP(loaded under Arduino-0.22) to program ATMega328's and ATtiny2313A's.
Make sure you have all the correct connections, the device 00 00 00 sounds like you are missing power to the device to be programmed.
Are both devices tied to a common ground?
Do you have Crystal or Resonator connected to the chip you wish to program?
You can type something like this from the command line to check your programming connections -
avrdude -P comport -b 19200 -c arduino -p m328 -v
Just change the comport to com4 or com9 or whatever comport yours shows up as.
I had to program using AVRDude because my chip was a 328 and not a 328P
kf2qd:
hmm...no they weren't. uno powered over USB and 328 powered by bench supply...
Yes with 18pF caps per datasheet
I'll try that on the next one.
I sent three off to KirAsh4 (he helped design a bunch of this project) so he can look at them. But I have a small feeling that it might be centered around uncommon ground.
actually, yes, the grounds were common at times, when I would use the FTDI cable to power the 328- then both the 328 and uno were running off the USB bus on my desktop.
This is on a bare 328 without any crystals or caps.
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
################################## | 100% 0.12s
         this check.
tried something different. Got the 8mhz internal clock file.
/Users/Steve/Downloads/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Users/Steve/Downloads/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P/dev/tty.usbmodem3d11 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xE2:m
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Recv: . [fd]
avrdude: Device signature = 0x00fd00
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
         Double check chip, or use -F to override this check.
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Recv: R [52]
avrdude: Device signature = 0x520000
running with -F from terminal:
custom:~ Steve$ /Users/Steve/Downloads/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Users/Steve/Downloads/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P/dev/tty.usbmodem3d11 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xE2:m  -F
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
Reading |                                                    | 0% 0.00savrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Recv: . [f7]
Reading | #################                                  | 33% 0.08savrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
Reading | ################################################## | 100% 0.12s
avrdude: Device signature = 0xf70000
avrdude: Send: V [56] P [50] . [00] . [00] . [00]   [20]
avrdude: safemode read 1, lfuse value: 0
avrdude: safemode read 2, lfuse value: 0
avrdude: safemode read 3, lfuse value: 0
avrdude: safemode: lfuse reads as 0
avrdude: Send: V [56] X [58] . [08] . [00] . [00]   [20]
avrdude: safemode read 1, hfuse value: 0
avrdude: Recv: . [88]
avrdude: safemode read 2, hfuse value: 88
avrdude: safemode: Verify error - unable to read hfuse properly. Programmer may not be reliable.
avrdude: safemode: To protect your AVR the programming will be aborted
custom:~ Steve$
last update till somebody replies. Again from terminal.
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: safemode read 2, hfuse value: 0
part 2 of that
avrdude: safemode read 3, hfuse value: 0
avrdude: safemode: hfuse reads as 0
avrdude: Send: V [56] P [50] . [08] . [00] . [00]   [20]
avrdude: safemode read 1, efuse value: 0
avrdude: safemode read 2, efuse value: 0
avrdude: safemode read 3, efuse value: 0
avrdude: safemode: efuse reads as 0
avrdude: Send: V [56] . [a0] . [03] . [fc] . [00]   [20]
avrdude: Send: V [56] . [a0] . [03] . [fd] . [00]   [20]
avrdude: Send: V [56] . [a0] . [03] . [fe] . [00]   [20]
avrdude: Send: V [56] . [a0] . [03] . [ff] . [00]   [20]
avrdude: erasing chip
avrdude: Send: V [56] . [ac] . [80] . [00] . [00]   [20]
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Writing |                                                    | 0% 0.00savrdude: Send: V [56] X [58] . [00] . [00] . [00]   [20]
avrdude: Send: V [56] . [ac] . [e0] . [00] . [ff]   [20]
avrdude: Recv: . [7f]
 ***failed;
Writing | ################################################## | 100% 0.32s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading |                                                    | 0% 0.00savrdude: Send: V [56] X [58] . [00] . [00] . [00]   [20]
Reading | ################################################## | 100% 0.04s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0x3f != 0x00
avrdude: verification error; content mismatch
avrdude: safemode: Fuses OK
custom:~ Steve$
tried loading blink for hell of it
Binary sketch size: 1042 bytes (of a 30720 byte maximum)
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P/dev/tty.usbserial-FTFBFE6C -b57600 -D -Uflash:w:/var/folders/cx/cxFzDNw2G2OZ5d+38E1XeU+++TI/-Tmp-/build8310694402898731267.tmp/Blink.cpp.hex:i
         Using Port            : /dev/tty.usbserial-FTFBFE6C
         Overriding Baud Rate  : 57600
