Bootloading SF SMD Simon
So I just finished my first surface mount project! (I got a new soldering station for christmas) I successfully (?) put together the Sparkfun surface mount Simon kit! I wanted to program it using the arduino IDE, and so I had to load the arduino bootloader, but this is where I've been having problems.
I'm using the arduino ISP setup, with a duemilanove. Here are the connections I made: With pin 1 on the Simon board's ISP header being the one with a line next to it, I have Pin 1 to D12 of the duemilanove 2 to 5v on the duemilanove 3 to 13 4 to 11 5 to 10 6 to GND
I have the arduino loaded with the ArduinoISP sketch and the leds mentioned in the sketch connected. The board selected is "ATmega328 on a breadboard (8 MHz internal clock)" from the arduino breadboard tutorial. from here.
Whenever I try to bootload the simon board, I get the message
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
I've also tried connecting the corresponding pins of both boards' ISP headers, but I get a avrdude: stk500_recv(): programmer is not responding Any ideas?
How can you tell which is pin 1 on the header? I can't see any alignment mark in the silkscreen.
For what it's worth, I can't see anything wrong with the way you've made the connections. They seem to match the description provided by Pololu for their USB programmer.
There is a line beside one of the pins. You see the outline of the header, but there is another line by pin 1.
I have also checked the continuity of each pin on the header with whereever it should be connected, 5v, gnd, and 4 pins of the uC, an so I am sure about the orientation of the header.
I have never tried bootloading a uC, so I feel like I may just be missing something software related, I think the hardware is correct.
Are you comfortable running AVRDUDE from the command-line?
Never done it, but I could try it.
At this point, there's no way to know if there's a software problem or a hardware problem. So, you'll need to "divide and conquer".
Hardware... Do you have a loose 168 or 328 processor and a breadboard? I ask because you can use them to ensure your "Arduino ISP" is working correctly. If it is working, then you'll know the problem is the Simon itself or the connection to the Simon.
Software... Start the Arduino IDE. Load or create a simple Sketch. While holding the Shift key, click the upload button. The AVRDUDE command line is displayed in the status window. Copy-and-paste the entire command line into a reply to this post. With that I'll be able to help you get a command shell setup to run AVRDUDE.
Oh, and what operating system are you using?
I didn't have a chance yet to try a separate chip, but here is the avrdude command line: I'm running mac osx 10.6
Binary sketch size: 1010 bytes (of a 30720 byte maximum)
/Users/[glow]my folders[/glow]/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Users/[glow]my folders[/glow]/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P/dev/tty.usbserial-A9007KIG -b57600 -D -Uflash:w:/var/folders/rm/rmdpTqY4GnKKnES8uoMbSk+++TI/-Tmp-/build2696334782939793404.tmp/Blink.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct  9 2007 at 11:20:31
         System wide configuration file is "/Users/[glow]my folders[/glow]/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/[glow]my user[/glow]/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port            : /dev/tty.usbserial-A9007KIG
         Using Programmer      : stk500v1
         Overriding Baud Rate  : 57600
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part              : ATMEGA328P
         Chip Erase delay      : 9000 us
         PAGEL                 : PD7
         BS2                   : PC2
         RESET disposition     : dedicated
         RETRY pulse           : SCK
         serial program mode   : yes
         parallel program mode : yes
         Timeout               : 200
         StabDelay             : 100
         CmdexeDelay           : 25
         SyncLoops             : 32
         ByteDelay             : 0
         PollIndex             : 3
         PollValue             : 0x53
         Memory Detail         :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     5     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [03]
         Hardware Version: 2
         Firmware Version: 1.16
avrdude: Send: A [41] . [84]   [20]
avrdude: Recv: . [00]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: u [75]   [20]
avrdude: Recv: . [14] . [1e] . [95] . [0f] . [10]
################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: Send: V [56] . [a0] . [03] . [fc] . [00]   [20]
avrdude: Send: V [56] . [a0] . [03] . [fd] . [00]   [20]
avrdude: Send: V [56] . [a0] . [03] . [fe] . [00]   [20]
avrdude: Send: V [56] . [a0] . [03] . [ff] . [00]   [20]
avrdude: reading input file "/var/folders/rm/rmdpTqY4GnKKnES8uoMbSk+++TI/-Tmp-/build2696334782939793404.tmp/Blink.cpp.hex"
avrdude: writing flash (1010 bytes):
Writing | avrdude: Send: U [55] . [00] . [00]   [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0c] . [94] a [61] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] . [9a] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [0c] . [94] ~ [7e] . [00] . [00] . [00] . [00] . [00] $ [24] . [00] ' [27] . [00] * [2a] . [00] . [00] . [00] . [00] . [00] % [25] . [00] ( [28] . [00] + [2b] . [00] . [00] . [00] . [00] . [00]   [20]
######avrdude: Send: U [55] @ [40] . [00]   [20]
avrdude: Send: d [64] . [00] . [80] F [46] # [23] . [00] & [26] . [00] ) [29] . [00] . [04] . [04] . [04] . [04] . [04] . [04] . [04] . [04] . [02] . [02] . [02] . [02] . [02] . [02] . [03] . [03] . [03] . [03] . [03] . [03] . [01] . [02] . [04] . [08] . [10]   [20] @ [40] . [80] . [01] . [02] . [04] . [08] . [10]   [20] . [01] . [02] . [04] . [08] . [10]   [20] . [00] . [00] . [00] . [07] . [00] . [02] . [01] . [00] . [00] . [03] . [04] . [06] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [11] $ [24] . [1f] . [be] . [cf] . [ef] . [d8] . [e0] . [de] . [bf] . [cd] . [bf]
(personal stuff edited)
Alright I tried with another chip.
**It was a 328 already loaded with the Duemilanove bootloader. (it was the only thing I had.)
Got the same error:
         this check.
If you open a command shell and try to run AVRDUDE, what happens?
What does this return...
avrdude -v
Using a breadboard?
The second chip I tested was on a breadboard, using the circuit shown in the minimal configuration in the arduino breadboard tutorial.
I tried the command you said, and here’s what I got:
avrdude: Version 5.8cvs, compiled on Jan 15 2010 at 17:27:01
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/usr/local/CrossPack-AVR-20100115/etc/avrdude.conf"
         User configuration file is "/Users/[glow]my username[/glow]/.avrduderc"
avrdude: no programmer has been specified on the command line or the config file
         Specify a programmer using the -c option and try again
