Bop it Arduino Circuit Playground
I'm trying to create a bop it game with 2 players where:
Green LED – Gyro Sensor (Z-axis)
Red LED – Temperature sensor
Blue LED – Sound sensor
Yellow LED – Light Sensor
However when I press the left button to start the game, only the yellow light above GND goes on and doesn't respond to anything, what can be wrong with my code?
long randNumber;
int temp;
int val;
int number;
int score;
boolean state;
int light;
uint8_t pixeln = 0;
int sound;
int shake;
unsigned long lastmillis = 0;
boolean game;
const byte numPins = 7;
byte pins[] = {0, 1, 2, 3, 4, 5, 6, 7};
int player1 = 0;
int player2 = 0;
#include "Adafruit_CircuitPlayground.h"
CircuitPlayground.begin();
CircuitPlayground.clearPixels();
//timer();
  if (digitalRead(4) == HIGH && digitalRead(19) == LOW){
    Serial.println("Button Pressed");
    lastmillis = millis();
    for (int i=0; i < 10; i  ){
      randNumber = random(4);
      //Serial.println("Loop");
      switch (randNumber){
        //Serial.println("Switch");
        case 0:
          while (pixeln < 10){
            CircuitPlayground.setPixelColor(pixeln  , 255,0,0);
            CircuitPlayground.strip.show();
          pixeln = 0;
          state = true;
          temp = analogRead(A0);
      //Serial.println(temp);
          while (state == true) {
            val = analogRead(A0);
number = val - temp;
            if (number > 10){
              score  ;
              state = false;
          //Serial.println("Temperature");
        case 1:
            CircuitPlayground.setPixelColor(pixeln  , 127,127,0);
          pixeln = 0;
          state = true;
          light = analogRead(A5);
        //Serial.println(light);
            val = analogRead(A5);
            number = light - val;
            if (number > 20){
              score  ;
              state = false;
              //Serial.println(number);
        case 2:
            CircuitPlayground.setPixelColor(pixeln  , 0,0,255);
          pixeln = 0;
          state = true;
          sound = analogRead(A4);
          //Serial.println(sound);
            val = analogRead(A4);
            number = val - sound;
            if (number > 50){
              score  ;
              state = false;
        case 3:
          CircuitPlayground.setPixelColor(pixeln  , 0,255,0);
          pixeln = 0;
          val = CircuitPlayground.motionZ();
          //Serial.println(val);
          state = true;
            shake = CircuitPlayground.motionZ();
            number = val - shake;
            if (number > 15 or number < -15){
              score  ;
              state = false;
            //Serial.println("shake");
         case 4:
             CircuitPlayground.setPixelColor(0, 0,255,0);
             CircuitPlayground.setPixelColor(1, 0,255,0);
             delay(3000);
         case 5:
             CircuitPlayground.setPixelColor(3, 255,0,0);
             CircuitPlayground.setPixelColor(4, 255,0,0);
             delay(3000);
         case 6:
             CircuitPlayground.setPixelColor(5, 127,0,255);
             CircuitPlayground.setPixelColor(6, 127,0,255);
             delay(3000);
         case 7:
             CircuitPlayground.setPixelColor(8, 255,128,0);
             CircuitPlayground.setPixelColor(9, 255,128,0);
             delay(3000);
  if (CircuitPlayground.slideSwitch()) {
    player1 = (millis() - lastmillis) / 1000;
    Serial.println(player1);
    byte num = player1;
    for (byte i=0; i < numPins; i  ){
      byte state = bitRead(num, i);
      if (state == 1){
        CircuitPlayground.setPixelColor(pins[i], 255,255,255);
    player2 = (millis() - lastmillis) /1000;
    Serial.println(player2);
    byte num = player2;
      if (state == 1){
CircuitPlayground.playTone(330, 500);
while (digitalRead(19) == HIGH && digitalRead(4) == LOW){
        if (player1 < player2){
          delay(250);
          for (int i =0; i < 5; i  ){
          CircuitPlayground.setPixelColor(i, 255,255,255);
          delay(250);
        else if (player1 > player2){
          delay(250);
          for (int i =5; i < 10; i  ){
          delay(250);
        else {
          delay(250);
          for (int i =0; i < 10; i  ){
          delay(250);
if (digitalRead(19) == HIGH && digitalRead(4) == HIGH){
  player1 = 0;
  player2 = 0;
  for (int a =0; a < 10; a  ){
     delay(100);
       CircuitPlayground.setPixelColor(i, CircuitPlayground.colorWheel(25 * i));
     delay(100);
You don't increment 'i' so the loop sits at i=0 forever. Is that a problem? You probably meant:
for (int i = 0; i < 10; i++) {
Similar in a BUNCH of other loops.
What board are you using? What version of the IDE? I'm trying to use Arduino 1.8.13 but the built-in Adafruit_CircuitPlayground library doesn't compile!
I'm using the Arduino Circuit Playground Express and running the same IDE
OK. Now that I know which board to pick I can get it to compile. The compiler points out the four places where you use "score. ;" as a statement that does nothing. Perhaps you meant "score++;"?
