Bop It Game, Code Correction
Hello All,
I am working on a bop it game for my engineering class. My game has 4 game levels and then a start and finish level. After completing each game level you are given a character displayed by the lcd. At the end of the game you are told all the characters.
The start level is supposed to tell you to press the start button to begin the game entering level 1. Level 1 is supposed to make you press the button and when you do it will give you a character moving on to the next stage but if you don't you're given a message telling you what to do. Level 2 is supposed to make you cover the photoresistor and when you do it will give you a character moving on to the next stage but if you don't you're given a message telling you what to do. Level 3 is supposed to make you be within 5 in of the distance sensor and when you do it will give you a character moving on to the next stage but if you don't you're given a message telling you what to do. Level 4 is supposed to make you be within 5-10 in of the distance sensor when you do it will give you a character moving on to the next stage but if you don't you're given a message telling you what to do. Endgame is supposed to tell you the characters you received from the game.
As this is a game I want to make sure these levels run in order, currently they run all at the same time, please help me if you can.
#include <LiquidCrystal.h>          //the liquid crystal library contains commands for printing to the display
LiquidCrystal lcd(13, 12, 11, 10, 9, 8);   // tell the RedBoard what pins are connected to the display
int photoresistor = 0;              //this variable will hold a value based on the brightness of the ambient light
int threshold = 700;                //if the photoresistor reading is below this value the the light will turn on
const int gameButton = 3; //gameButton pin 3
const int startButton = 4; //startButton pin 4
const int trigPin = 7;           //connects to the trigger pin on the distance sensor
const int echoPin = 6;           //connects to the echo pin on the distance sensor
float distance = 0;               //stores the distance measured by the distance sensor
  Serial.begin(9600);               //start a serial connection with the computer
  lcd.begin(16, 2);                 //tell the lcd library that we are using a display that is 16 characters wide and 2 characters high
  lcd.clear();                      //clear the display
  pinMode(13, OUTPUT);              //set pin 13 as an output that can be set to HIGH or LOW
  //set the button pins as inputs
  pinMode(trigPin, OUTPUT);   //the trigger pin will output pulses of electricity
  pinMode(echoPin, INPUT);    //the echo pin will measure the duration of pulses coming back from the distance sensor
  start();
  level1();
  level2();
  level3();
  level4();
  endgame();
//------------------FUNCTIONS-------------------------------
//Start
void start() {
  // to start round
  lcd.clear();
  lcd.setCursor(0, 0);              //set the cursor to the 0,0 position (top left corner)
  lcd.print("Press start ");       //print hello, world! starting at that position
  lcd.setCursor(0, 1);              //move the cursor to the first space of the bottom row
  lcd.print("to play! ");
  if (digitalRead(startButton) == HIGH) {
    level1();
//Round1
void level1() {
  lcd.clear();
  lcd.print("Press game ");       //print hello, world! starting at that position
  lcd.print("button! ");
  if (digitalRead(gameButton) == HIGH) {
    lcd. clear();
    lcd.print("Correct!");       //print correct! starting at that position
    lcd.print("Character: C");       //print the number of seconds that have passed since the last reset
    lcd.clear();
    lcd.print("Please press");       //print correct! starting at that position
    lcd.print("Game button");       //print the number of seconds that have passed since the last reset
//Round2
void level2() {
  //read the brightness of the ambient light for photoresistor
  photoresistor = analogRead(A0);   //set photoresistor to a number between 0 and 1023 based on how bright the ambient light is
  Serial.println(photoresistor);    //print the value of photoresistor in the serial monitor on the computer
  lcd.clear();
  lcd.print("Cover the ");       //print hello, world! starting at that position
  lcd.print("photoresistor! ");
  //if the photoresistor value is below the threshold turn the light on, otherwise turn it off
  if (photoresistor < threshold) {
    delay (100);
    lcd. clear();
    lcd.print("Character: P");
    lcd.clear();
    lcd.print("Please cover");       //print correct! starting at that position
    lcd.print("photoresistor");       //print the number of seconds that have passed since the last reset
//Round3
void level3 () {
  //for distance sensor
  distance = getDistance();   //variable to store the distance measured by the sensor
  Serial.print(distance);     //print the distance that was measured
  Serial.println(" in");      //print units after the distance
  delay (100);
  lcd.clear();
  lcd.print("Be less than ");       //print hello, world! starting at that position
  lcd.print("5 in away! ");
  if (distance < 5) {                       //if the object is close
    lcd.clear();
    lcd.print("Correct! ");       //print hello, world! starting at that position
    lcd.print("Character: N");       //print the number of seconds that have passed since the last reset
    lcd.clear();
    lcd.print("Please move");       //print correct! starting at that position
    lcd.print("closer");
    //if the object is a medium distance
//Round4
void level4 () {
  lcd.clear();
  lcd.print("Be within ");       //print hello, world! starting at that position
  lcd.print("5-10 in ");
  if (5 < distance && distance < 10) {                       //if the object is close
    lcd.clear();
    lcd.print("Character: D");       //print the number of seconds that have passed since the last reset
  } else if ( 0 < distance && distance < 5) {
    lcd.clear();
    lcd.print("back");
//End
void endgame() {
  lcd.clear();                    //clear the screen
  lcd.setCursor(0, 0);            //move the cursor to the top center of the screen
  lcd.print("Characters:");               //print "You"
  lcd.setCursor(0, 1);            //move the cursor to the bottom center of the screen
  lcd.print("CPND");              //print "WIN!"
//RETURNS THE DISTANCE MEASURED BY THE HC-SR04 DISTANCE SENSOR
float getDistance()
  float echoTime;                   //variable to store the time it takes for a ping to bounce off an object
  float calculatedDistance;         //variable to store the distance calculated from the echo time
  //send out an ultrasonic pulse that's 10ms long
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  digitalWrite(trigPin, LOW);
  echoTime = pulseIn(echoPin, HIGH);      //use the pulsein command to see how long it takes for the
  //pulse to bounce back to the sensor
  calculatedDistance = echoTime / 148.0;  //calculate the distance of the object that reflected the pulse (half the bounce time multiplied by the speed of sound)
  return calculatedDistance;              //send back the distance that was calculated
Thanks in advance,
RH
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Where is the } at the end of the setup() function ?
i fixed the brackets so i no longer have errors but I do need to get the levels to play in order instead of all at one time simultaneously. Do you know how I can fix that?
  start();
  level1();
  level2();
  level3();
  level4();
  endgame();
//Start
void start() {
  // to start round
  lcd.clear();
    level1();
//Round1
void level1() {
  lcd.clear();
    lcd. clear();
    lcd.clear();
//Round2
void level2() {
  lcd.clear();
    delay (100);
    lcd. clear();
    lcd.clear();
//Round3
void level3 () {
  delay (100);
  lcd.clear();
    lcd.clear();
    lcd.clear();
//Round4
void level4 () {
  lcd.clear();
    lcd.clear();
    lcd.clear();
    lcd.print("back");
//End
void endgame() {
float getDistance()
The error messages have been resolved but I'm still not sure how to make the events transpire in order rather than simultaneously all at one time.
Take a look here
