sorry, no, not at the moment ... still working on it
also i switched from the avr to an arm cortex-m3 from nxp (lpc1347)
i inherited (licensed) initially an atmega 328 design where i didn't have the org source code and only some early publicly available source in avr "basic" or so ... since my hw had initial problems, i wrote my own test code in arduino C++ to diagnose my issues ... yes i had the broken wire already back then ... what a night mare ... feel kind of dumb but got over it.
gut tired of fighting the restrictions of the avr implementation of the harvard architecture (code and data space at same addr) ... and more ... having strings and const data put into code space and using printf in the same fashion was a const juggling act and standing on your head while doing it ... then for every 16 or 32 bit calculation worrying about how slow it's gonna be
the LPCXpresso IDE also offers a free C++ environment ... the code runs at 72 MHz on a 32 bit cortex m3 with divide instr.
a usb based jtag controller and target cpu board cost's less than $ 30.-- ... LPC1347 (yes with rom'ed USB api) is about $ 3.-- or so in moderate qtys.
since the LPCXpresso does not support the creation of a C++ projects out of the box, but it can be done, i dedicated a wiki page at my efiHacks.com wiki with a simple sample project for download ... sorry no cj code in the sample
link -> http://wiki.efihacks.com/index.php?title=LPCXpresso_CPP
it's an early snapshot of a LPC1347 project and should still work.
leave me a note if anything seems not to work
also ... back to the org question about code library for the cj125
not that easy in an embedded environment and i will explain why
even it's in highly modular C++ classes, i would have to provide between 48 and 64 k of interacting code
i have a timer running at 2400 Hz sampling all analog channels according to a channel select table ... every Nth time i switch this table to a UR and UA calibration table to read cali vals ... the 16 bit spi token is fast enough so that i can poll for it to finish. the adc vals can be filtered at the same time.
what this gives me is an independently running data acquisition system, where i only need to look at the data anytime i like without any more software overhead
now in main i use sw-timers from my timer isr to process a 20 Hz PID control loop for the heater control
at 100 Hz i run the PWM analog out calcs ... and so on
that's roughly where i'm about now
so can you imagine that it would not be too easy to follow ... or pack it into a stand alone portable library and provide an api for it
for search term purpose i mention again :
C++ with LPCXpresso, LPC1347
hope this helps for the moment
cheers, blue2u
p.s. i could possibly release the avr test code i wrote for the cj ... it follows the same strategy and gets the data from the cj ... i guarantee you it's gonna be a night mare to make it fit in the 32k / 2k on an avr and then how slow will it crawl along ... yes the "basic" code worked in less than 32 k but is was bare, bare minimum and hard to follow
as long as you don't want to ship 1000s / month it's prohibitive to use an 8-bit cpu for a project like this.
