Both USB & DC jack plugged in: which does Arduino use?
I need a stable 5V reference for analogRead, so I want to power the board through the DC jack, but I also need to record data serially through the USB cable at the same time. Ideally if they are both plugged in, I can use USB for data while the board draws power from the AC adapter. Is this actually what would happen?
If the voltage on the DC jack is above 6.6V then the power is taken from the DC jack.
Got it! Thanks
If Vin is >6.6V, the barrel is used.
Vin is after the reverse polarity protection diode, so Vbarrel really needs to be > ~ 7.3V.
