my test project like this
#include <GxEPD2_BW.h>
#include <GxEPD2_3C.h>
#include <SD.h>
#define GxEPD2_DISPLAY_CLASS GxEPD2_BW
#define GxEPD2_DRIVER_CLASS GxEPD2_420
#define GxEPD2_BW_IS_GxEPD2_BW true
#define GxEPD2_3C_IS_GxEPD2_3C true
#define GxEPD2_7C_IS_GxEPD2_7C true
#define GxEPD2_1248_IS_GxEPD2_1248 true
#define IS_GxEPD(c, x) (c##x)
#define IS_GxEPD2_BW(x) IS_GxEPD(GxEPD2_BW_IS_, x)
#define IS_GxEPD2_3C(x) IS_GxEPD(GxEPD2_3C_IS_, x)
#define IS_GxEPD2_7C(x) IS_GxEPD(GxEPD2_7C_IS_, x)
#define IS_GxEPD2_1248(x) IS_GxEPD(GxEPD2_1248_IS_, x)
#define MAX_DISPLAY_BUFFER_SIZE 65536ul // e.g.
#if IS_GxEPD2_BW(GxEPD2_DISPLAY_CLASS)
#define MAX_HEIGHT(EPD) (EPD::HEIGHT <= MAX_DISPLAY_BUFFER_SIZE / (EPD::WIDTH / 8) ? EPD::HEIGHT : MAX_DISPLAY_BUFFER_SIZE / (EPD::WIDTH / 8))
#elif IS_GxEPD2_3C(GxEPD2_DISPLAY_CLASS)
#define MAX_HEIGHT(EPD) (EPD::HEIGHT <= (MAX_DISPLAY_BUFFER_SIZE / 2) / (EPD::WIDTH / 8) ? EPD::HEIGHT : (MAX_DISPLAY_BUFFER_SIZE / 2) / (EPD::WIDTH / 8))
#elif IS_GxEPD2_7C(GxEPD2_DISPLAY_CLASS)
#define MAX_HEIGHT(EPD) (EPD::HEIGHT <= (MAX_DISPLAY_BUFFER_SIZE) / (EPD::WIDTH / 2) ? EPD::HEIGHT : (MAX_DISPLAY_BUFFER_SIZE) / (EPD::WIDTH / 2))
#endif
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ 15, /*DC=*/ 4, /*RST=*/ 16, /*BUSY=*/ 17));
#include "bitmaps/Bitmaps400x300.h"
SPISettings spi_settings(4000000, MSBFIRST, SPI_MODE0);
SPIClass hspi(HSPI);
unsigned char buf[32];
#define LENG 16 //0x3c + 0x2 + 15 bytes equal to 17 bytes
const char HelloWorld[] = "Hello World!";
hspi.begin(14, 12, 13, 15); // remap hspi for EPD (swap pins)
display.epd2.selectSPI(hspi, SPISettings(4000000, MSBFIRST, SPI_MODE0));
display.init(115200);
void helloWorld()
//Serial.println("helloWorld");
display.setRotation(1);
display.setTextColor(GxEPD_BLACK);
int16_t tbx, tby; uint16_t tbw, tbh;
display.getTextBounds(HelloWorld, 0, 0, &tbx, &tby, &tbw, &tbh);
// center bounding box by transposition of origin:
uint16_t x = ((display.width() - tbw) / 2) - tbx;
uint16_t y = ((display.height() - tbh) / 2) - tby;
display.setFullWindow();
display.firstPage();
do
display.fillScreen(GxEPD_WHITE);
display.setCursor(x, y);
display.print(HelloWorld);
while (display.nextPage());
my chip is esp32-wroom32
my spi pin like this
when I restart without sdcard, it works well,but when I put my sdcard in and restart, it will always print like this:
10:01:24.735 -> rst:0x7 (TG0WDT_SYS_RESET),boot:0x37 (SPI_FAST_FLASH_BOOT)
10:01:24.735 -> configsip: 0, SPIWP:0xee
10:01:24.735 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
10:01:24.735 -> mode:DIO, clock div:1
10:01:24.781 -> load:0x3fff0030,len:1344
10:01:24.781 -> load:0x40078000,len:13864
10:01:24.781 -> load:0x40080400,len:3608
10:01:24.781 -> csum err:0xa8!=0x51
10:01:24.781 -> ets_main.c 384
10:01:25.064 -> ets Jul 29 2019 12:21:46
how I can solve this problem? it hardware problem or software problem ?
