i have no clue on how to program, learning slowly but have all hardware in place,
my main struggle is getting info from the flow sensor and to turn off the relay when it has reached a value.
I was able to get information from the flow sensor with a pi 3 b+ but i think a Arduino will best suit my project
so essentially i am looking for a quick code i can put in place and edit if need be to run a cycle.
the cycle needed is
button push ---> open valve ----> flow sensor reaches value (x)---> valve close ---> end of cycle
the code can just run one relay and sensor then i can replicate it to do all 6 when that is working
There are plenty of examples to start from on line --> for example this one seems to be close to what you want to do.
I would recommend though that you invest first a bit of time to understand programming and the commonly used arduino libraries, that will save you some headache later on
well if i get this working id be happy to share to all still very new to this whole new world i have jumped into, its very exciting, thanks for the leads trying them now
