And the bottom 2 lines do not light up at all, top two are mostly readable but cut in and out. Not turn on and off, just cut in and out. PS, this application is with an existing control system that required several pins to be swapped around, when first plugged in the DB pins were swapped, so 1 and 2 were 2 and 1. 3 and 4 were 4 and 3 etc.
Again, I know this isn't an Arduino specific problem but looking for any kind of advice on it.
IIRC that display is logically divided into TWO displays. Don't quote me tho as the mind is foggy, but I seem to recall reading that. Something about dual channels or controllers or some such.
Yepper - from the data sheet:
void writedata1(char i) //Top half of the display
P1 = i;
W = 0;
RS = 1;
E1 = 1;
delay(2);
E1 = 0;
void writedata2(char i) //Bottom half of the display
P1 = i;
W = 0;
RS = 1;
E2 = 1;
delay(2);
E2 = 0;
Sounds like the second Enable pin is either not correctly connected or connected to the wrong wire. Old screen didn't come with a pinout and I had to test all the pins to find the VSS, VDD and NC then swap around the Vo, Grnd, E1, E2 and R/W till it turned on. And then I only have the top 2 lines, so probably the E2 is plugged into the Vo... Gonna have to swap some more wires around and get back to you all next week.
Happy holidays and thank you for the information!
PS, I am thinking the weird character display is due to dirt/oil on between at the zebra pins, possibly noise because the Vo isn't grounded?
That is a possibility but I doubt it because I checked the pins on the existing setup so the NC and the DB pins were all in the right places, before ever hooking up the new screen. Still, not sure why the old board has 2 +5v? one is power but the other? And I might have hooked one of the +5v to the R/W
I am not using a code or library. This is an existing OLD machine from the 1995. I don't have an Arduino any longer, lost my old serial Arduino from back in like 2006. What possible problems could cause the bottom 2 lines to display only boxes?
UPDATE: screen zebra stripes were not aligned correctly, top 2 lines are now displaying 100% correctly.
I know the R/W R/S NC, Grnd and E1 are all connected correctly. I know DB 0-3 OR 4-7 are connected correctly. If I remove any cable, the screen does not turn on! If I remove the Vo (contrast) it doesn't turn on. If I remove E2 it doesn't turn on, same with R/w R/S, E1.
I have also tried to swap around the Vo and E2 for example, the screen won't turn on.
As far as I can tell at this time
Pins 1-8 are DB, not certain of correct orientation, but with lines 1 and 2 displaying properly but 3 and 4 displaying nothing. I would assume 4, 5,6 and 7 DB are correct, possible 0-3 are connected backwards though I can't imagine why the old screen would be Pins 1-7 DB 7-6-5-4-0-1-2-3? Would this even cause this issue?
Pins: (coming out of the old board, not the pinout on the new screen)
9 E1
10 R/W
11 R/S
12 E2
13 Grnd (for sure)
14 VDD
15 NC
16 Vo
Considering the pinout on the new screen, 12 goes to 15, 15 to 16 and 16 to 12. I have tried it with 12 to 16 and 16 to 12, screen does not turn on. swapping 11 to 16 or 15 and 12 to 11 burned out 11
If this is a question regarding the old board, I know not. The entire wiring is weird, from the DB pins to the Enable pins the only ones that really make sense are the R/W R/S and E1 Nothing else matches anything I can find or have ever used. Of course, the machine has parts from Japan, Taiwan, America, Germany and Italy so Honestly not surprised nothing is plug and play on it (plus it IS 25 years old)
Also, last time I worked with screens of this kind, removing the R/W R/S or Vo pins didn't prevent the screen from turning on, just stopped it from displaying anything. All that was truly necessary was the NC, VDD and Ground, basically, apply voltage it turns on, it doesn't DO anything, but it does turn on. This controller doesn't turn the screen on without all the other pins in place though.
