I'm BRAND new to Arduino.
I'm attempting to build a midi footswitch.
I installed the Bounce2 library which included Bounce (version 1). I have tried and tried to get this to work and read all the threads about changing "WProgram.h" to "Arduino.h" in the cpp file. That didn't work.
Below is my code...
#include <Bounce.h>
// define how many pots are active up to number of available analog inputs
#define analogInputs 8
// make arrays for input values and lagged input values
int inputAnalog[analogInputs];
int iAlag[analogInputs];
// make array of cc values
int ccValue[analogInputs];
// index variable for loop
int i;
// cc values for buttons
int cc_off = 0;
int cc_on = 65;
int cc_super = 127;
// map buttons to cc for button
int cc0 = 51;
int cc1 = 52;
int cc2 = 53;
int cc3 = 54;
Bounce button0 = Bounce(0, 3);
Bounce button1 = Bounce(1, 3);
Bounce button2 = Bounce(2, 3);
Bounce button3 = Bounce(3, 3);
// MIDI rate
Serial.begin(31250);
pinMode(0, INPUT_PULLUP);
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
pinMode(10, INPUT_PULLUP);
pinMode(11, INPUT_PULLUP);
// loop trough active inputs for knobs
for (i=0;i<analogInputs;i++){
// read current value at i-th input
inputAnalog[i] = analogRead(i);
// if magnitude of difference is 8 or more...
if (abs(inputAnalog[i] - iAlag[i]) > 7){
// calc the CC value based on the raw value
ccValue[i] = inputAnalog[i]/8;
// send the MIDI
usbMIDI.sendControlChange(i, ccValue[i], 3);
// set raw reading to lagged array for next comparison
iAlag[i] = inputAnalog[i];
delay(5); // limits MIDI messages to reasonable number
// Push Button code
button0.update();
button1.update();
button2.update();
button3.update();
if (button0.fallingEdge())
usbMIDI.sendControlChange(cc0, cc_on, 3);
if (button1.fallingEdge())
usbMIDI.sendControlChange(cc1, cc_on, 3);
if (button2.fallingEdge())
usbMIDI.sendControlChange(cc2, cc_on, 3);
if (button3.fallingEdge())
usbMIDI.sendControlChange(cc3, cc_on, 3);
if (button0.risingEdge())
usbMIDI.sendControlChange(cc0, cc_off, 3);
if (button1.risingEdge())
usbMIDI.sendControlChange(cc1, cc_off, 3);
if (button2.risingEdge())
usbMIDI.sendControlChange(cc2, cc_off, 3);
if (button3.risingEdge())
usbMIDI.sendControlChange(cc3, cc_off, 3);
Here is the Bounce.cpp file code
#include “Arduino.h”
Bounce::Bounce(uint8_t pin,unsigned long interval_millis)
interval(interval_millis);
previous_millis = millis();
state = digitalRead(pin);
this->pin = pin;
void Bounce::write(int new_state)
this->state = new_state;
digitalWrite(pin,state);
void Bounce::interval(unsigned long interval_millis)
this->interval_millis = interval_millis;
this->rebounce_millis = 0;
void Bounce::rebounce(unsigned long interval)
this->rebounce_millis = interval;
int Bounce::update()
if ( debounce() ) {
rebounce(0);
return stateChanged = 1;
// We need to rebounce, so simulate a state change
if ( rebounce_millis && (millis() - previous_millis >= rebounce_millis) ) {
rebounce(0);
return stateChanged = 0;
unsigned long Bounce::duration()
return millis() - previous_millis;
int Bounce::read()
return (int)state;
// Protected: debounces the pin
int Bounce::debounce() {
uint8_t newState = digitalRead(pin);
if (state != newState ) {
if (millis() - previous_millis >= interval_millis) {
state = newState;
return 1;
return 0;
// The risingEdge method is true for one scan after the de-bounced input goes from off-to-on.
bool Bounce::risingEdge() { return stateChanged && state; }
// The fallingEdge method it true for one scan after the de-bounced input goes from on-to-off.
bool Bounce::fallingEdge() { return stateChanged && !state; }
Every time I verify, I get this error...
/Users/dallaskruse/Documents/Arduino/libraries/Bounce1/Bounce.cpp:4:22: fatal error: WProgram.h: No such file or directory
#include "WProgram.h"
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
Just on a whim I entered #include <Bounce2.h> in my Arduino code but that left me with a myriad of other error messages I don't understand.
can anyone help please?
