bounce2 library problem
as all,
I need help please with simple example.
Led goes high for 2 seconds instead of 1. Why is that? I used default code and added a delay(1000); line
 DESCRIPTION
 Simple example of the Bounce library that switches the debug LED when
 either of 2 buttons are pressed.
// Include the Bounce2 library found here :
// https://github.com/thomasfredericks/Bounce2
#include <Bounce2.h>
#define BUTTON_PIN_1 2
#define BUTTON_PIN_2 3
#define LED_PIN 13
// Instantiate a Bounce object
Bounce debouncer1 = Bounce();
// Instantiate another Bounce object
Bounce debouncer2 = Bounce();
  // Setup the first button with an internal pull-up :
  pinMode(BUTTON_PIN_1,INPUT_PULLUP);
  // After setting up the button, setup the Bounce instance :
  debouncer1.attach(BUTTON_PIN_1);
  debouncer1.interval(5); // interval in ms
   // Setup the second button with an internal pull-up :
  pinMode(BUTTON_PIN_2,INPUT_PULLUP);
  debouncer2.attach(BUTTON_PIN_2);
  debouncer2.interval(5); // interval in ms
  //Setup the LED :
  pinMode(LED_PIN,OUTPUT);
  // Update the Bounce instances :
  debouncer1.update();
  debouncer2.update();
  // Get the updated value :
  int value1 = debouncer1.read();
  int value2 = debouncer2.read();
  // Turn on the LED if either button is pressed :
  if ( value1 == LOW || value2 == LOW ) {
    digitalWrite(LED_PIN, HIGH );
  else {
    digitalWrite(LED_PIN, LOW );
How are your switches wired?
