I can not make the library Bounce2 works. I have downloaded it but still doesn't work.
Forget about using the library.
Just scan for switch state changes every 50ms.
BTW always show your work.
Use CTRL T to format your code.
Attach your sketch between code tags
[code]Paste your sketch here[/code]
On the other hand, this is what I use often for switch handling.
/*SwitchManager skeleton
This sketch is to introduce new people to the SwitchManager library written by Nick Gammon
The library handles switch de-bouncing and provides timing and state change information in your sketch.
The SwitchManager.h file should be placed in your libraries folder, i.e.
C:\Users\YourName\Documents\Arduino\libraries\SwitchManager\SwitchManager.h
You can download the library at:
http://gammon.com.au/Arduino/SwitchManager.zip Thank you Nick!
In this example we have 2 normally open (N.O.) switches connected to the Arduino - increment and decrement.
The increment switch will also be used as a "Reset" switch if pressed for more than two seconds.
The two switches are connected between GND (0 volts) and an Arduino input pin.
The library enables pull-up resistors for your switch inputs.
Pushing a switch makes its pin LOW. Releasing a switch makes its pin HIGH.
The SwitchManager library provides 10ms de-bounce for switches.
i.e. enum { debounceTime = 10, noSwitch = -1 };
If you need more time, edit the SwitchManager.h file
i.e. enum { debounceTime = 50, noSwitch = -1 }; //here it is changed to 50ms
#include <SwitchManager.h>
//object instantiations
SwitchManager myIncSwitch;
SwitchManager myDecSwitch;
unsigned long currentMillis;
unsigned long heartBeatMillis;
unsigned long heartFlashRate = 500UL; // time the led will change state
unsigned long incShortPress = 500UL; // 1/2 second
unsigned long incLongPress = 2000UL;// 2 seconds
unsigned long decShortPress = 500UL; // 1/2 second
const byte heartBeatLED = 13;
const byte incSwitch = 4; //increment switch is on Arduino pin 4
const byte decSwitch = 5; //decrement switch is on Arduino pin 5
int myCounter;
//gives a visual indication if the sketch is blocking
pinMode(heartBeatLED, OUTPUT);
myIncSwitch.begin (incSwitch, handleSwitchPresses);
myDecSwitch.begin (decSwitch, handleSwitchPresses);
//the handleSwitchPresses() function is called when a switch changes state
} // E N D O F s e t u p ( )
//leave this line of code at the top of loop()
currentMillis = millis();
//some code to see if the sketch is blocking
if (CheckTime(heartBeatMillis, heartFlashRate, true))
//toggle the heartBeatLED
digitalWrite(heartBeatLED,!digitalRead(heartBeatLED));
//check to see what's happening with the switches
//"Do not use delay()s" in your sketch as it will make switch changes unresponsive
//Use BlinkWithoutDelay (BWD) techniques instead.
myIncSwitch.check ();
myDecSwitch.check ();
//put other non-blocking stuff here
} // E N D O F l o o p ( )
// F U N C T I O N S
// C h e c k T i m e ( )
//Delay time expired function
//parameters:
//lastMillis = time we started
//wait = delay in ms
//restart = do we start again
boolean CheckTime(unsigned long & lastMillis, unsigned long wait, boolean restart)
//has time expired for this task?
if (currentMillis - lastMillis >= wait)
//should this start again?
if(restart)
//yes, get ready for the next iteration
lastMillis = millis();
return true;
return false;
} // E N D o f C h e c k T i m e ( )
// h a n d l e S w i t c h P r e s s e s ( )
void handleSwitchPresses(const byte newState, const unsigned long interval, const byte whichPin)
// You get here "ONLY" if there has been a change in a switches state.
//When a switch has changed state, SwitchManager passes this function 3 arguments:
//"newState" this will be HIGH or LOW. This is the state the switch is in now.
//"interval" the number of milliseconds the switch stayed in the previous state
//"whichPin" is the switch pin that we are examining
switch (whichPin)
//are we dealing with this switch?
case incSwitch:
//has this switch gone from LOW to HIGH (gone from pressed to not pressed)
//this happens with normally open switches wired as mentioned at the top of this sketch
if (newState == HIGH)
//The incSwitch was just released
//was this a short press followed by a switch release
if(interval <= incShortPress)
Serial.print("My counter value is = ");
myCounter++;
if(myCounter > 1000)
//limit the counter to a maximum of 1000
myCounter = 1000;
Serial.println(myCounter);
//was this a long press followed by a switch release
else if(interval >= incLongPress)
//we could also have an upper limit
//if incLongMillis was 2000UL; we could then have a window between 2-3 seconds
//else if(interval >= incLongMillis && interval <= incLongMillis + 1000UL)
//this could be used to change states in a StateMachine
//in this example however, we will just reset myCounter
myCounter = 0;
//if the switch is a normally closed (N.C.) and opens on a press this section would be used
//the switch must have gone from HIGH to LOW
Serial.println("The incSwitch was just pushed");
break; //End of case incSwitch
case decSwitch:
//The decSwitch was just released
if(interval <= decShortPress)
myCounter--;
if(myCounter < 0)
//don't go below zero
myCounter = 0;
Serial.println("The decSwitch switch was just pushed");
break; //End of case decSwitch
//Put default stuff here
//default:
//break; //END of default
} //End switch (whichPin)
} // E n d o f h a n d l e S w i t c h P r e s s e s ( )
// E N D O F C O D E
larryd:
There's nothing wrong with that library, pretty tight and well-written code. It works well.
hashemuh:
That's such a piss-poor problem statement that it hardly deserves a reply. Try the examples that come with the library. Come back when you're ready to properly tell us what the problem is.
I can't find Bounce2 library that works. I have downloaded many libraries but still not working.
Please describe exactly what you mean by "not working".
Please don't cross post!
http://forum.arduino.cc/index.php?topic=584073
I have reported this thread to the moderators.
Duplicate posts waste the time of the people helping you. I might spend 15 minutes writing a detailed answer on this thread, without knowing that someone already did the same in the other thread. This behavior is very disrespectful to the people you're asking for assistance. Just because we give our time freely doesn't mean it has no value.
In the future, take some time to pick the forum section that best suits the topic of your question and then only post once to that forum section. This is basic forum etiquette, which you would already know if you had read the sticky "How to use this forum - please read." post you will find at the top of every forum section. It contains a lot of other useful information. Please read it.
Threads merged.
