Bounce2 with more than one button
Hallo, I want to use more than one button, but I am not shure, how I must write the code! Can you please help me!?
Many thanks.
#define button1 10
#define button2 11
pinMode(button1,INPUT_PULLUP);
pinMode(button2,INPUT_PULLUP);
if (digitalRead(button1)==LOW)
   Serial.println("Blobby Blobby");
if (digitalRead(button2)==LOW)
   Serial.println("Bloop Bloop");
That doesn't show how to use the Bounce2 library for two buttons. This does:
#include <Bounce2.h>
DESCRIPTION
Simple example of the bounce library that switches the debug LED when a button is pressed.
Adapted for 2 switches by JimboZA July 2014
CIRCUIT
https://raw.github.com/thomasfredericks/Bounce-Arduino-Wiring/master/Bounce/examples/circuit-bounce-change-duration-retrigger.png
#define BUTTON_PINA 2
#define LED_PINA 12
#define BUTTON_PINB 3
#define LED_PINB 11
// Instantiate 2 Bounce object
Bounce debouncerA = Bounce();
Bounce debouncerB = Bounce();
  // Setup the buttons
  pinMode(BUTTON_PINA,INPUT_PULLUP);
  pinMode(BUTTON_PINB,INPUT_PULLUP);
  // After setting up the button, setup debouncer
  debouncerA.attach(BUTTON_PINA);
  debouncerA.interval(5);
  debouncerB.attach(BUTTON_PINB);
  debouncerB.interval(5);
  //Setup the LED
  pinMode(LED_PINA,OUTPUT);
    pinMode(LED_PINB,OUTPUT);
 // Update the debouncer
  debouncerA.update();
    debouncerB.update();
 // Get the update value
 int valueA = debouncerA.read();
  int valueB = debouncerB.read();
 // Turn on or off the LED
 if ( valueA == HIGH) {
   digitalWrite(LED_PINA, HIGH );
    digitalWrite(LED_PINA, LOW );
  if ( valueB == HIGH) {
   digitalWrite(LED_PINB, HIGH );
    digitalWrite(LED_PINB, LOW );
JimboZA:
Aha! Bounce2 is a library. I thought it was some kind of game :slight_smile:
Many thanks for the example.
One question:
which pin uses "#define BUTTON_PINA 2"? Is that Pin 2? And the alphabetic character for the bounce is "A"? Is that correct?
Many thanks
