Hello Im having issues with using a bourns encoder and I2c backpack. I am receiving random values in the serial monitor as if the encoder is bouncing around. Could this be a pin mapping issue?
#include <ACE128.h>
#include <ACE128map87654321.h>
/* ACE128 Demonstrator
* This demo provides examples of all the options and functions available in this library.
* You should be able to find everything you need from here to use in your own sketch.
* This makes is very long, detailed and wordy.
* See the ace128_0x20 and ace128_0x38 examples for short specific tests for the manufactured modules.
* As distributed it can be used to test the functionality of the Absolute Encoder modules
* that I make and distribute online on AVR platforms e.g. Arduino Unos.
* If you wire a button between pin 13 and ground, you can test setting logical zero
* For use on non-AVR chips (e.g. Arduino MKR) and use without PCF8574(A) pin expanders, see below.
* The inline comments do not assume the use of one of my modules, so there are references to
* mis-wiring and alternate wiring which are relevent to people building their own circuits or breadboarding.
* The value below is the address of your module. Set this to the correct value.
* For purchased modules this is the base address of the module.
//PCF8574 0x20
//#define PCF8574A 0x38
// MCP23008 0x00 (see notes below)
#define ACE_ADDR 0x38
* this sketch displays the current position in all five forms on the serial monitor at 9600 baud
* pin = the raw gray-code from the pins. As you rotate this will rise and fall in steps of 1,2,4,8,16,32,64 or 128
* raw = the output from the encoder map table. This should rise from 0 - 127 as you rotate clockwise
* if it jumps around and shows 255 a lot - your wiring does not match your encoder map. Check your wiring
* and your object declaration. See the make_encodermap example sketch to create encoder maps for
* alternate pin arrangements
* pos = this is the raw value converted to the range -64 - +63 relative to the logical zero. Logical zero is
* wherever it was when the sketch started, unless the value was saved in EEPROM or reset.
* upos = this is the raw value converted to the range 0 - 127 relative to the logical zero
* mpos = this is like pos, but goes multiturn -32768 - 32767
* For this sketch we need to select what displays we will use
#define DISPLAY_SERIAL // display on serial at 9600 baud
//#define DISPLAY_LCD // display on LCD with PCF8574 backpack at 0x27
#ifdef DISPLAY_LCD
#include <LiquidCrystal_PCF8574.h>
LiquidCrystal_PCF8574 lcd(0x27); // 1602 LCD on 0x27
#endif
* Your sketch needs to include the ACE128.h library near the top
* For the following non-standard options you need to edit some options in ACE128.h
* disabling EEPROM storage code on AVR platforms
* enabling I2C EEPROM storage on all platforms - you can also change the default I2C address of this EEPROM
* enabling direct-wire to the ACE128 - this disables all the pin-expander chip code
* enabling support for MCP23008 pin expanders (this does not disable PCF8574(A) support)
* These options will be documented in detail below.
* Note that if you are having trouble editing the ACE128.h file in the library folder you can copy it to your sketch folder
* and edit it there. If you do this, use the second #include format below
#include <ACE128.h> // Include the ACE128.h from the library folder
// #include "ACE128.h" // Include the ACE128.h from the sketch folder
/* Now we include the encoder map.
* This is a table of all the 256 possible pin combinations and how they map to the 128 gray code values.
* Invalid locations are filled with 255.
* The modules I make all use the 87654321 map and this is silkscreened on the circuit board. If you are building your
* own circuits or breadboarding you may need another encoder map. Several are available in the library, as well as an
* example sketch to generate new ones.
* Each map is identified by the sequence of numbers 1 thru 8 in the order that they appear on the P0 - P7 pins of the chip
#include <ACE128map87654321.h> // mapping for pin order 87654321
/* MCP23008 pin expanders are optionally supported. I built my first modules using these but the code is no longer
* included by default and must be enabled by defining ACE128_MCP23008 in ACE128.h
* Both modules can be used on the same project but as the MCP and PCF address ranges overlap we tell them apart by
* calling the contructor with I2C address range 0x00-0x07 which is mapped internally to the actual 0x20-0x27 range
* The following little bit of preprocessor code helps for this sketch as we need the mapped address
* for bus probing
#ifdef ACE128_MCP23008
#define ACE_PROBE_ADDR ACE_ADDR | 0x20
#else
#endif
* Now construct an ACE128 object for each unit in your project
* There are 4 constructors available. Providing a choice of I2C or direct pin mode and with or without EEPROM state storage
ACE128 myACE(ACE_ADDR, (uint8_t*)encoderMap_87654321); // I2C without using EEPROM
// the EEPROM contructor is not available on SAM based platforms unless ACE128_I2C_EEPROM is defined in ACE128.h
//ACE128 myACE(ACE_ADDR, (uint8_t*)encoderMap_87654321, 0); // I2C using EEPROM address 0
* If wiring directly to the ACE128 sensor, the constructors below are enabled by defining ACE128_ARDUINO_PINS
* in ACE128.h - this also disable I2C chip capabilities.
* In this case the 8 numbers identify arduino digital pins. So you can shuffle those numbers around instead of
* changing the encoder map. Have fun!
//ACE128 myACE(uint8_t{2,3,4,5,6,7,8,9}, (uint8_t*)encoderMap_87654321); // direct pins without using EEPROM
//ACE128 myACE(uint8_t{2,3,4,5,6,7,8,9}, (uint8_t*)encoderMap_87654321, 0 ); // direct pins using EEPROM address 0
// the following stuff is for this example script
// set-zero button on pin 13
// - button to ground e.g. MakerShield button
const int ZERO = 13;
uint8_t pinPos = 0; // pin values
uint8_t rawPos = 0;
uint8_t upos = 0;
uint8_t oldPos = 255;
int8_t pos;
int16_t mpos;
uint8_t seen = 0;
myACE.begin(); // this is required for each instance, initializes the pins
pos = myACE.pos(); // get logical position - signed -64 to +63
upos = myACE.upos(); // get logical position - unsigned 0 to +127
mpos = myACE.mpos(); // get multiturn position - signed -32768 to +32767
if (upos != oldPos) { // did we move?
oldPos = upos; // remember where we are
Serial.print(" pos ");
Serial.print(pos, DEC);
Serial.print(" upos ");
Serial.print(upos, DEC);
Serial.print(" mpos ");
Serial.println(mpos, DEC);
Here is what the serial monitor returns:
pos 0 upos 0 mpos -128
pos -1 upos 127 mpos -129
pos 0 upos 127 mpos -129
pos 0 upos 43 mpos -85
pos -38 upos 90 mpos -38
pos -38 upos 41 mpos -87
pos 41 upos 56 mpos -72
