box Lock
I'm planning on creating some sort of storage lock box, but I am stuck, I don't know what to use as a lock I saw some people use servos but I believe that is not efficent do you guys know of any better way?
Why isn't a servo efficient? You can use a simple slide bolt and a cheap servo and make a strong lock. If you want to go overkill, a solenoid would work, but be slightly harder to match travel-wise.
Explain what you mean by this.
Hey,
You can use electromagnet lock or an actuator.
The above things can be easily controlled using an arduino.
Hope this helps
thanks for sharing, ill prob use an electric one
