Thanks for your reply!
But I dont see anything on my serial monitor even after changing the code. I am using a UNO board with baud set to 9600.
Also, &r1 and &r2 takes the two inputs for computation as sigma is set to 2 as per the code. So in this case how r1 and r2 gets the values to compute?
I mean should we provide the inputs from a knob / keyboard?
I tried to input the r1 and r2 values from keyboard ranging between 0 and 1 and clicked send on the serial monitor. When I clicked, the Rx pin is receiving the data from keyboard as it is blinking for the input data..But there is no output seen even after the autoscrolling is turned ON!
Below is the code for your perusal!
void box_muller(double sigma, double *r1, double *r2);
randomSeed(analogRead(0));
double r1,r2;
box_muller(2, &r1, &r2);
if(r1 >=0) Serial.print(" ");
Serial.print(r1);
Serial.print("; ");
if(r2 >= 0)Serial.print(" ");
Serial.println(r2);
delay(100);
double
u1,u2,
v1,v2,s,
z1,z2;
for(;;){
v1 = 2.0Lu1 - 1.0L;
v2 = 2.0Lu2 - 1.0L;
s = v1*v1 + v2 * v2;
if(s<= 1.0L && s != 0.0L)
z1 = sqrt(-2.0L * log(s) / s) * v1;
z2 = sqrt(-2.0L * log(s) / s) * v2;
if(r1 != NULL) r1 = (z1sigma);
if(r2 != NULL) r2 = (z2sigma);
return;
