So, say you're commissioned to fix the leakage (I assume we've all heard of this load of bs that's been going on) now that James Cameron failed (he was supposedly commissioned by the government as a consultant a month back or so). How would you go about it?
Stick to the rule of K.I.S.S., but if you have a good Arduino related idea, it's worth more brownie points so post it as well.
I suspect BP really does want to stop oil flowing into the Gulf. But, I also suspect they have only considered ideas that allow them to move the well into production.
Does "fix the leakage" include ideas that permanently damage / ruin the well?
I doubt anything with an Arduino will help - I do wonder if this idea has been considered (and I realize this is all "armchair"):
What if (perhaps via one of the relief wells, or perhaps straight into the damaged well) they injected liquid methane or propane into the well - at that depth and temperature, as soon as the methane/propane hit the water, shouldn't frozen hydrates form, plugging the well with a frozen hydrate plug?
/very armchair, and I don't understand the physics/chemistry involved...
//oh, and put an Arduino on it to monitor gas flow...
Yeah, I read someone's suggestion somewhere that you put a tube around the well, and pump liquid nitrogen through it to make the oil sludge, thus allowing you to fill the hole with mud/cement.
You've rumbled us Brits, it is all a plot to make your seas as contaminated as ours he he he.
Some people will believe anything you know.
You mean like BP is a British company called British Petroleum?
It stopped being British years ago, and is just BP now. Of course, calling it British and blaming us is only natural - hollywood has spent the last couple of decades pegging Brits as bad guys.
I would have swarms of small autonomous robots, arduino controlled. They would be equipped with basic homing communications. When one happens upon oil it would signal how much oil it is in.
Arduinos would decide where to go based on the strength of the signal (to indicate distance) and the amount of oil. A big patch of oil would attract arduinos to clean it up. Little patches of oil would only attract particularly bored arduinos.
I've seen the news, and as a child in the 80s I remember the footage of the exxon valdize spill. I know without a doubt that the best thing in the world at soaking up oil is air beathing marine wildlife: birds, seals, etc.
Each arduino would have an animal in a little bag (with its own air supply, I'm not cruel). Seawater would be pumped over the animal, which would soak up the oil and clean seawater would exit the vehicle. Once fully soaked the arduino woulddump the animal on shore where a team of do-gooding greenies would clean up the animal and return it to the wild (where it would be caught by BP staff and set in another robot).
The best thing is the clean-up people don't even have to know what's going on!
Hold on, oil is a fuel. Surely any machine at all that could be fueled by crude oil could be set free in the sea and it'd help? Maybe capture exhaust gasses - this would mean full units would float, making them easy to collect, empty and redeploy.
Crude oil is not the same as diesel fuel; heck, its not even close to bunker fuel, which is almost a leftover of the refining process. AFAIK, while you can burn crude oil, you can't power an engine with it (and you really wouldn't want to, either - the emissions alone would be pretty nasty, and it would like foul the engine before it turned many revolutions anyhow).
