Hallo!
Ich möchte den Blutdruck per CNIBP messen, das heißt dauerhaft und ohne Manschette. Dazu gibt es Geräte wie zB den: Breaking Down Continuous Non-Invasive Blood Pressure (cNIBP) (soterawireless.com)
Hierzu heißt es:
otera’s cNIBP technique is based on a principle called Pulse Arrival Time. To obtain cNIBP, you need both sensors of the ViSi Mobile Monitoring System: the thumb sensor and the chest sensor, plus the cuff module for initial calibration.
The Pulse Arrival Time is the time from the onset of the R-wave of the ECG, to the arrival of the resulting pulse at the base of the thumb. The resulting pulse arrival time correlates with blood pressure. Since every patient has a different cardiovascular profile, an initial “calibration measurement” is taken by means of a cuff-based measurement. For this you use a standard Welch Allyn FlexiPort cuff with the ViSi Mobile cuff module attached to it. This measurement is taken on inflation, during which a “patient specific cardiovascular profile” is created. This profile then allows to measure blood pressure on a beat-to-beat basis.
Zudem gibt es Task Force Monitor, CNAP Monitor 500, CNAP Smart Pod and in the LiDCOrapid. (VERIFI) und Finapres (PhysioCal), auf Wiki Continuous noninvasive arterial pressure - Wikipedia heißt es dazu:
The pitfall of all noninvasive technologies is change in vascular tone. Small arteries beginning from arteria radialis downwards to the periphery have smooth muscles in order to open (vasodilation) and close (vasoconstriction). This human mechanism is activated by sympathetic tone and is further influenced by vasoactive drugs. Especially in critical care, vasoactive drugs are needed to control and maintain sedation and blood pressure. Mathematically advanced correction methods have to be developed for these noninvasive technologies in order to fulfill accuracy and clinical acceptance:
für den Arduino fand ich folgendes Modul:
Measure SpO2, Heart Rate and BP Trends (BPT) Using Arduino - Arduino Project Hub
Aber ob der BP Trent hier das Problem erücksichtigt das im Wiki angesprochen wird? und wenn ja, kann ich den BP auch mit dem Modul messen? GitHub - Protocentral/Pulse_MAX30102 Den Sensor hab ich nämlich.
Ad 2. Welches ESP würdet ihr für den Verlinkten O2 Sensor nehmen? Den Maxim 30102? Den hier? : D1 MINI: D1 Mini - ESP8266, v3.0 bei reichelt elektronik und folgenden Akku: Lithium Polymer Batterie 3.7V 480mAh mit JST Connector (semaf.at) oder den? Arduino Nano 33 BLE: Amazon.de: Elektronik
MFG
