Hello,
I am Babu, I am doing my project on Arduino along with the BQ25887 IC for battery charging of 2S li-ion battery. Can anyone send me some example code for controlling the BQ IC's along with the arduino.
Welcome! That sounds like an interesting project. What have you accomplished so far? Post your preliminary schematic, not a frizzy thing showing all connections. Include links to technical information on all the hardware devices. Also post your code as you have it. We are more than willing to help you but I will not do the project for you.
Google is your friend: arduino - Issues reading from an I2C device - Electrical Engineering Stack Exchange
And the example code:
#include <Wire.h>
#define ADDR 0x6A
Serial.begin(9600); // start serial for output
Wire.begin();
Wire.beginTransmission(ADDR);
Wire.write(0x0D);
Wire.endTransmission();
Wire.requestFrom(ADDR, 1); // request 1 byte from slave
while (Wire.available()) { // slave may send less than requested
char c = Wire.read(); // receive a byte as character
Serial.println(c); // print the character
So far I have created a evaluation board on my own for the BQ25887 IC, my doubt is regarding how to interface the Arduino with BQ25887 IC and I would like to know how to interface these kind of IC using coding, like any example code file so that I can learn and create on my own
Thanks for this example code, do you have created any library for this IC BQ25887 or have you used this IC earlier
No, I gust googled it. Since this is an i2c device, it would be pretty straight forward to take an existing library for an i2c device and change it for this IC.
