Braccio +++ problems
Hello, I try my new braccio ++ today, and I have a question for the signification of the leds'colors.
When USB C is installed, the arm started to move and at the end all the led are green but the led 5 is blinking green an red.
I don't know what the signification of this led 5 and why it's blinking.
There are 6 green light on the LCD and the joystick doesn't work.
The arm doesn't work and and need to be reboot and the end takes always the same issue
Someone could help me please?
For reference: [edit] my post references the wrong Braccio. See Post #3.[/edit]
The shield contains three status LEDs:
Green LED (LED ON) signals that the shield is on
Another green LED (LED OK) signals that the shield is correctly powered
A red LED (LED ERR) signals that the shield is not correctly powered
Probably your wiring.
Probably your power supply.
That information is for the original TinkerKit Braccio. The Braccio++ is a different product. The documentation for the Braccio++'s control board is here:
https://docs.arduino.cc/hardware/braccio-carrier/
And it uses the Nano RP2040 Connect board:
https://docs.arduino.cc/hardware/nano-rp2040-connect/
