Braccio Robotarm several starting problems
Hallo,
This is my first post here in this forum (and in any forum in general), so I hope I chose the right topic for my issues.
My first problem is that I have troubles with uploading a sketch to my arduino board, with the shield attached to it.
I always get the error: avrdude stk500_getsync( ) attempt 10 of 10: not in sync: resp=0x20
My current method to solve the problem is to upload the sketch to the board without the shield attached.
After that I put shield and board together and connect the powercord to my Braccio shield. With this method everything is functioning flawless.
But this can´t be the solution for ever... I also searched on youtube, google and this forum but found nothing
with my specific problem.
My second question: Is there any possibility teaching this robotarm without creating an own app (I´m not that familiar with coding. Thats why I try to get my self interested in it, by working with this robotarm). I watched a clip about this on the youtube arduino channel where some people asked the same question but got no response.
Information about Arduino board and the shield.:
Board: Arduino UNO R3 (without WIFI function)
Shield: Braccio Shield V4
Best regards
Rob
I can only venture a guess at this point but my first would be to be sure the Baud is set correctly and all are the same. It is possible you are getting a conflict on the serial pin that is connected to the shield. The serial pin 0 and 1 are used by the boot loader. This is a starting point, sorry I cannot be of more help.
rob_24:
Hallo,
Best regards
Rob
gilshultz:
Hello ,
I had the same Problem when i connect the an Bluetooth Module to my arduino unsing pins 1 and 0;
The problem is that pins 1 and 0 are using from usb port to connect with to microcontroller that attached to Arduino Borad (in you case is ( ATmega328P ) )
and because they are used to connect with usb they are used to uploading the sketch. and when you connect any thing to them you loss your serial Communication ability
for this reasion you need to unplug every thing is connected to this pins while uploading the sketch then you can pulg them again.
if you want to learn more about this tow pins and more about Sreial Communication , i advice you to read this documantion form arduino Reference > Language > Functions > Communication > Serial
Hi and hello,
I have the same Problem the topic owner has.
The Uno works fine. But I can't reprogramm it when the braccio shield is installed.
Arduino: 1.8.12 (Linux), Board: "Arduino Uno"
Der Sketch verwendet 4612 Bytes (14%) des Programmspeicherplatzes. Das Maximum sind 32256 Bytes.
Globale Variablen verwenden 418 Bytes (20%) des dynamischen Speichers, 1630 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem beim Hochladen auf das Board. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload.
Dieser Bericht wäre detaillierter, wenn die Option
"Ausführliche Ausgabe während der Kompilierung"
in Datei -> Voreinstellungen aktiviert wäre.
I tested it with to different UNOs and two different Computers. Always the same.
The Uno and the braccio is sold as a bundle:
https://store.arduino.cc/braccio-bundle
Couldn'T believe that there is no work around or solution.
Best regards
Here I found my Solution in another part of the forum:
In my case it was a soldering bridge on the backside of the motor shield between two pins.
Foto is attached in the link.
Hope this could help some other people.
