# Braking Function in Old (rev1?) Arduino Motor Shield
**URL:** <https://forum.arduino.cc/t/braking-function-in-old-rev1-arduino-motor-shield/523257>\
**Category:** Motors, Mechanics, Power and CNC\
**Created:** [April 29, 2018, 5:08pm UTC](https://forum.arduino.cc/t/braking-function-in-old-rev1-arduino-motor-shield/523257 "2018-04-29T17:08:24Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![chca](https://avatars.discourse-cdn.com/v4/letter/c/6de8d8/32.png) [@chca](https://forum.arduino.cc/u/chca)\
**Post date:** [April 29, 2018, 5:08pm UTC](https://forum.arduino.cc/t/braking-function-in-old-rev1-arduino-motor-shield/523257/1 "2018-04-29T17:08:24Z")
</div>
apparently I bought an older revision of the arduino motor shield, which does not quite seem to function like what the schematic of the newer rev3 suggests.
My shield looks like this: [Arduino Motor Shield Rev3 - RobotShop](https://www.robotshop.com/en/arduino-motor-shield-rev3.html)
The current one like this: [Arduino Motor Shield Rev3 — Arduino Official Store](https://store.arduino.cc/arduino-motor-shield-rev3)
The logic circuitry on the right seems to have changed. According to the schematic
> **[arduino\_MotorShield\_Rev3-schematic.pdf](https://www.arduino.cc/en/uploads/Main/arduino_MotorShield_Rev3-schematic.pdf)**
> 81.29 KB
I would expect that a low level on DIRA as well as a high level on BRAKEA would make the motor to be tied to ground with low impedance (except for the current sensing resistor). Instead, the DIRA state does not matter and the motor outputs are always tied to supply when BRAKEA is high. I do not want this behavior in my application.
Does anyone have a schematic of this hardware revision? I did not find one anywhere.
**Author:** ![bos1714](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/bos1714/32/277648_2.png) [@bos1714](https://forum.arduino.cc/u/bos1714)\
**Post date:** [May 2, 2018, 5:32pm UTC](https://forum.arduino.cc/t/braking-function-in-old-rev1-arduino-motor-shield/523257/2 "2018-05-02T17:32:49Z")
</div>
Hi there!
I have found schematics and PCB layouts for each version and the schematics are identical.
The Robotshop picture shows multiple small packages, whereas the Arduino website shows one big package, which I'm guessing is the difference you mentioned.
Most likely, the bigger package has simply combined all of the small packages into one to reduce space on the PCB.
I share your concern that the braking signal sends both motor channels to the supply. Technically speaking this is acceptable, however it is much safer and a better practice to send both channels to ground for active breaking. As such, you may not be able to use this shield if you don't want this braking method.
As an alternative, the Pololu Dual MC33926 Motor Shield is very similar and can be used to power two DC motors at the same time, each with its own direction and speed. Better yet, it has leads to fit right onto an Arduino Uno, but also has leads to control it separately. I would suggest looking into this shield if you don't need the servo and solenoid capability of the Arduino shield.
> **[Pololu Dual MC33926 Motor Driver Shield for Arduino](https://www.pololu.com/product/2503)**
> This shield makes it easy to control two brushed DC motors with your Arduino or Arduino-compatible board. Its dual MC33926 motor drivers operate from 5 to 28 V and can deliver a continuous 3 A per motor. These great drivers also offer...
Good luck!
P.S. I'm new to the forums so apologies in advance if I didn't post the link correctly 🙂
**Post date:** [May 6, 2021, 9:47am UTC](https://forum.arduino.cc/t/braking-function-in-old-rev1-arduino-motor-shield/523257/3 "2021-05-06T09:47:54Z")
</div>
