Brand new to this stuff (kinda)
I used to program in college but that was 20 years ago now and I am back to basics. I am trying to figure out how to add a button to this code to control it. Once pressed I want it to only run once, and then stop. I have looked at other examples but I am either not integrating it right or I'm botching it on the breadboard. Any assistance would be appreciated.
CODE
Fade
This example shows how to fade an LED on pin 9
using the analogWrite() function.
This example code is in the public domain.
int led = 9; // the pin that the LED is attached to
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
// the setup routine runs once when you press reset:
// declare pin 9 to be an output:
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
// set the brightness of pin 9:
analogWrite(led, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// check to see if we are ready for flash
if (brightness > 150) {
// flash the led
analogWrite(led, 255);
delay(50);
// start the dimming effect
fadeAmount = -fadeAmount ;
Serial.println(brightness);
if (brightness <= 0) {
fadeAmount = -fadeAmount;
// wait for 30 milliseconds to see the dimming effect
delay(30);
Take a look at the state change example in the IDE's code examples.
Please remember to use code tags when posting code.
Sorry, again, new.... :frowning: I will delete
Goodbye. Deleted profile. Sorry to have bothered anyone.
jamstraz:
Wow.
jamstraz:
From introduction to opus in three posts. That's gotta be a new record.
jamstraz:
I don't know if the deletion is automatic or it needs intervention/approval of the Moderator. In the past, I tried to delete my profile; but, it was never deleted. I think that you are still alive in the Forum and just continue.
Here, how you can go connecting a button with your sketch, which when pressed will cause your sketch to run only once.
1. Connect K1 with DPin-2 (with internal pull-up enabled) as per Fig-1.
Figure-1:
2. Upload the following sketch (tested).
int counter = 0;
  // pinMode(led, OUTPUT);
  pinMode(2, INPUT_PULLUP);    //internal pull-up resistor is connected
  while (digitalRead(2) != LOW)  //check if the button is pressed; if not wait until closed
  counter = 0;
  do
      // flash the led
      delay(50);
      counter++;
    delay(30);
  while (counter != 1);
3. Just press K1 and check the fading effect on the LED for one cycle.
4. Once the process is stopped repeat Step-3.
