Brand new user here and running into problems with Nano Every
Good evening all,
I have just bought 3 x nano every boards and am trying to get them to upload the blink example just to prove they work.
So for information I am running windows 10 and connecting the board to my PC via a USB port and that is also providing power. I have also downloaded the IDE program as directed from the windows store.
I have followed the "Getting Started" guide on the nano every page and all was going well, so far I have this selected:
Board: Arduino Nano Every
Registers Emulation: ATMEGA328
Port: COM5 (Arduino Nano Every)
I load up the default blink example and verify that and it comes up with the message done compiling, when I try to upload it I get the following output:
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Walshy690\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : jtag2updi
         Overriding Baud Rate          : 115200
JTAG ICE mkII sign-on message:
Communications protocol version: 1
M_MCU:
  boot-loader FW version:        1
  firmware version:              1.07
  hardware version:              1
S_MCU:
  firmware version:              6.07
  hardware version:              1
Serial number:                   00:00:00:00:00:00
Device ID:                       JTAGICE mkII
         AVR Part                      : ATmega4809
         Chip Erase delay              : 0 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 0
         StabDelay                     : 0
         CmdexeDelay                   : 0
         SyncLoops                     : 0
         ByteDelay                     : 0
         PollIndex                     : 0
         PollValue                     : 0x00
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           prodsig        0     0     0    0 no         61   61      0     0     0 0x00 0x00
           fuses          0     0     0    0 no          9    0      0     0     0 0x00 0x00
           fuse0          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse1          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse2          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse4          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse5          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse6          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse7          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse8          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0     0     0 0x00 0x00
           data           0     0     0    0 no          0    0      0     0     0 0x00 0x00
           usersig        0     0     0    0 no         64   64      0     0     0 0x00 0x00
           flash          0     0     0    0 no      49152  128      0     0     0 0x00 0x00
           eeprom         0     0     0    0 no        256   64      0     0     0 0x00 0x00
         Programmer Type : JTAGMKII_PDI
         Description     : JTAGv2 to UPDI bridge
         M_MCU hardware version: 1
         M_MCU firmware version: 1.07
         S_MCU hardware version: 1
         S_MCU firmware version: 6.07
         Vtarget         : 5.0 V
avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.27s
avrdude: Device signature = 0x1e9651 (probably m4809)
avrdude: erasing chip
avrdude: reading input file "C:\Users\WALSHY~1\AppData\Local\Temp\arduino_build_744700/Blink.ino.hex"
avrdude: writing flash (1120 bytes):
Writing | ################################################## | 100% 0.84s
avrdude: 1120 bytes of flash written
avrdude: verifying flash memory against C:\Users\WALSHY~1\AppData\Local\Temp\arduino_build_744700/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\WALSHY~1\AppData\Local\Temp\arduino_build_744700/Blink.ino.hex:
avrdude: input file C:\Users\WALSHY~1\AppData\Local\Temp\arduino_build_744700/Blink.ino.hex contains 1120 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.15s
avrdude: verifying ...
avrdude: 1120 bytes of flash verified
avrdude: reading input file "0x01"
avrdude: writing fuse2 (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of fuse2 written
avrdude: verifying fuse2 memory against 0x01:
avrdude: load data fuse2 data from input file 0x01:
avrdude: input file 0x01 contains 1 bytes
avrdude: reading on-chip fuse2 data:
Reading | ################################################## | 100% 0.00s
avrdude: 1 bytes of fuse2 verified
avrdude: reading input file "0xC9"
avrdude: writing fuse5 (1 bytes):
avrdude: 1 bytes of fuse5 written
avrdude: verifying fuse5 memory against 0xC9:
avrdude: load data fuse5 data from input file 0xC9:
avrdude: input file 0xC9 contains 1 bytes
avrdude: reading on-chip fuse5 data:
avrdude: 1 bytes of fuse5 verified
avrdude: reading input file "0x00"
avrdude: writing fuse8 (1 bytes):
avrdude: 1 bytes of fuse8 written
avrdude: verifying fuse8 memory against 0x00:
avrdude: load data fuse8 data from input file 0x00:
avrdude: input file 0x00 contains 1 bytes
avrdude: reading on-chip fuse8 data:
avrdude: 1 bytes of fuse8 verified
avrdude done.  Thank you.
When the upload is happening I can see the blinking yellow LED (The L LED) flashing faster similar to a HDD light when there is activity. However when I reset or unplug then plug it back in the L LED flashes slowly (like it's ready to have something uploaded).
I have tried this on 3 separate Nano Every boards and I get the same result each time and I'm just a little confused as to whats going on really.
Any help is much appreciated.
You have posted the output of a successful upload. So everything is fine and you can go back to having fun with Arduino. Enjoy!
That's my problem it looks like it works but I cannot get the LED to flash even when pressing the "RST" button or unplugging the USB and plugging it back in again.
Little confused really.
walshy690:
What do you mean by "slowly"? The standard File > Examples > 01.Basics > Blink sketch blinks the LED at 0.5 Hz, which I would classify as "slowly", so it sounds to me like you are getting the expected results.
pert:
What do you mean by “slowly”? The standard File > Examples > 01.Basics > Blink sketch blinks the LED at 0.5 Hz, which I would classify as “slowly”, so it sounds to me like you are getting the expected results.
I’ve just gone through and changed it to 10 seconds on 10 seconds off and that now works…I was thinking it was using a different LED I thought it was meant to use the one in the middle of the board (TX or RX). I’ve uploaded the code from my mac and that works fine, I will try again from my windows machine tomorrow to see if that also has the same effect.
Seems like I was a bit daft. Thanks for confirming.
OK, I'm glad to hear that things are working as expected now. I'll hope for the same on the Windows machine!
