Bread board Arduino error.
Title ^
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
enabled in File > Preferences.
And your circuit is what ?
UKHeliBob: And your circuit is what ?
http://www.notesandvolts.com/2012/12/fun-with-arduino-arduino-on-breadboard.html
if you have still same problem try version 1.0.6
https://www.arduino.cc/en/Main/OldSoftwareReleases
Is what you have built equivalent to an "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
WhereIsMyMind: if you have still same problem try version 1.0.6
I tried this is what i get.
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences. Arduino: 1.0.6 (Windows NT (unknown)), Board: "Arduino Mega 2560 or Mega ADK" avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x50 avrdude: initialization failed, rc=-1 Double check connections and try again, or use -F to override this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
UKHeliBob: Is what you have built equivalent to an "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
I think its more of a uno.
Then why not set the board type to Uno ?
Yes i find a solution i hope; If you are have cheap USBasp programmer u can try this http://www.instructables.com/id/USBASP-Bootloading-a-ATMega328p-with-a-8mhZ-intern/
gageglade: http://www.notesandvolts.com/2012/12/fun-with-arduino-arduino-on-breadboard.html
That shows an Atmega328P.
That is not a Arduino Mega or Mega 2560, ATmega2560.
http://www.gammon.com.au/breadboard
I have installed arduino 1.6.5 windows version, i am using arduino pro mini and usbaps programmer. i work fine with previous version (1.6.0.) but and having issues with 1.6.5. the error report as error report i get each time i use "upload using programmer" Error while uploading: missing 'program.tool' configuration parameter
What's the objection to going back to a working version of the IDE?
Hi, Are you using a 328 that is loaded with the bootloader? Are you using the instructions in the tutorial following the linked page?
Tom.... :)
