I am bread-boarding an arduino and I am positive I have all the connections correct ive check multiple times. When i go to use the FTDI cable to upload the sketch (blink) i get the
"avrdude: stk500_getsync(): not in sync: resp=0x00" error message.
I have tried to press reset on upload, the board i have selected is Duemilanove w/ ATmega328, and the port is right, but still no go.
Yes, VCC and AVCC must both be connected.
0.1uF from each to Gnd is also very beneficial. Buy a small bagful from dipmicro.com or taydaelectronics.com, you will need them for every project.
How did you burn the fuses and install a bootloader onto the chip?
Are you selecting the proper board type for that bootloader?
I burn all my '328P chips as if they were an Uno for use with 16 MHz crystal.
Thanks everyone for all the awesome help, i had a couple things i was doing wrong, but with your guys help i got my little green LED blinking away!!!!!! SUPER STOKED!!!
