Breadboard Help
I am new to arduino and electronics. I am attempting to follow several videos online and putting the led on the arduino it lights up but as soon as I connect it to the breadboard it does not. this is the code I am using and a pic of the breadboard. I have put the short led pin on the left.
pic located at "http://www.zerobitsolutions.com/sites/arduino.jpg"
int switchPin = 8;
int ledPin = 9;
boolean lastButton = LOW;
boolean currentButton = LOW;
int ledLevel = 0;
  pinMode (switchPin, INPUT);
  pinMode (ledPin, OUTPUT);
boolean debounce(boolean last)
  boolean current = digitalRead(switchPin);
  if (last != current)
    delay(5);
  return current;
  currentButton = debounce(lastButton);
  if (lastButton == LOW && currentButton == HIGH)
     ledLevel = ledLevel + 51;
   lastButton = currentButton;
  if (ledLevel > 255) ledLevel = 0;
  analogWrite(ledPin, ledLevel);
The long leg on the LED is normally the anode or positive end. Either reverse the LED, or connect the short leg to ground instead of to +5V.
I can guess what you want to achieve.
Pushing the button increases the brightness of the LED
Off (0) -> Very Dim (51) -> Dim (102) -> Normal (153) -> Bright (204) -> Very Bright (255) -> Off (0) -> ...
So you should put the shorter pin on the RIGHT instead because the shorter pin is cathode (-)
I tried that but the led only lights up very dim for 5 times then off. it never goes to full power.
got it working I needed a bigger resistor. Once I put a 200 it worked.
thx
Hi, just a quick question. Im a beginner as well, and Im looking at the same piece of code. Im wondering about this line:
Dont we have to set some kind of value on this "last"? When the program scans and reaches this line, what does it think this last is? I see its not defined anywhere else outside of that part. thanks XD
d1n0:
Maybe should be this boolean debounce(boolean lastbutton)
Wait, let me rephrase my question. I dont wana open the new topic since this is a same piece of code. Look at this:
    delay(5);
  return current;
In that IF loop, he is comparing last and current. Ok I understand that current has a value whatever is read on the switchPin. However, Last does not have any value, defined anywhere in the program. So it can be either true or false. What decides if its true or false?
The only logical answer is that there is a hidden default value which Im not seeing. As in boolean last; means boolean last = false ;
Is that correct? can anyone confirm this?
This is a function declaration. The bit between parentheses is the parameter list for the function. In this case, the local (to the debounce() function) variable last will receive the value put in the parentheses when the function is called.
Here, the debounce() function is being called. The value of lastButton is being passed to the function, and last will receive that value.
Does that help?
You beat me to it.... :slight_smile:
There`s no reason not to have a function before the main loop, but I would put the functions after it, does that make any difference?
dxw00d:
Does that help?
EDIT: I figured it out. This function is not part of the void setup. my mistake :slight_smile:
I was under the impression the program reads line by line, and that void setup is done first, only once , then it passes to void loop. Im asking about this first cycle. Does he not test that IF loop in void setup at first cycle then? Only when its actually being called?
Thanks for your patience, Im sure the question is trivial, however I am just a beginner in this world. :slight_smile:
Nope, that function is not called in Void Setup, only in the main loop.
Void Setup is executed first which only sets the pin modes for the switch and LED pins.
Void Loop is executed next, this is the part that calls the Debounce function.
You could move the debounce function code block to the bottom of the code after the end of the main loop code and it should still work the same. (I think, try it :slight_smile: )
Edit just tried it, and it compiles ok.
int switchPin = 8;
int ledPin = 9;
int ledLevel = 0;
    delay(5);
  return current;
yup it works, u can put it anywhere out of the void setup () and void loop () and it will work.
