Breadboard Layout for Reversible Stepper Motor Activated by PIR
What's up guys, I'm a beginner and I'm working on a project for school that uses a PIR Sensor to activate a DC motor when it senses motion, and then turns the motor the opposite direction after a delate of 5 seconds or so. I can put the breadboard layout together for the DC motor alone or the PIR sensor alone, but I cant find any examples online for both together.
A DC motor is not a stepper motor. Which one do you have? If there's a web link or datasheet, that would be helpful to answer your question.
Well, don't give up. If it was already on the internet then you would just be an assembly technician copying a hopefully-working design. Now you're a hacker, making your own design.
You probably noticed that the two projects you did find don't use all the holes and strips in the breadboard? Can all of the components of one project fit in the empty holes of the other project? Why not try that first?
