Hi!
Two questions:
1 - How can I change the setting of this link (http://arduino.cc/en/Tutorial/ArduinoToBreadboard) for use with Arduino Uno?
2 - How can I connect a TFT display in this configuration?
Tks
wrobbi
Hi!
Two questions:
Tks
wrobbi
If you mean to use the Uno as the programming board, for bootloading the only difference is to add a 10uF electrolytic capacitor between reset and GND. Electrolytic capacitors are polarised so the grey/white stripe defining the negative pin goes to the GND connection.
If you mean to make the Breadboard Arduino a Uno, then that's simply a matter of using the latest bootloader.
For the answer to question 2 you'd need to specify which TFT display you're intending to use.
Cheers ! Geoff
Hi!
The TFT display is:
Tks
Ah then you've made it easy for yourself - Adafruit has a tutorial here for that.
Cheers ! Geoff
