break code in loop
Hello all
I would like to have the following code run three time then stop. How would I change this?
#include <Servo.h>
Servo servoRight;
Servo servoLeft;
  servoLeft.attach(4);  // Left Servo is connected to digital pin 4
  servoRight.attach(5);  // Right Servo is connected to digital pin 5
  servoLeft.writeMicroseconds(1300);  // clockwise
  servoRight.writeMicroseconds(1700);
  delay(2000);                      // Wait 2 seconds
  servoLeft.writeMicroseconds(1700);  // Counter clockwise
  servoRight.writeMicroseconds(1300);
  delay(2000);
  servoLeft.writeMicroseconds(1550);  // Stop
  servoRight.writeMicroseconds(1550);
  delay(2000);
Use if, and a variable that starts out as 0, and which is incremented.
When the variable is < 3 the if statement is true and your statements will execute.
When the variable is => 3, your statements won’t execute.
Put the code in a for loop (for(int n = 0; n < 2; n++)) and put that in setup so the code will go through 3 iterations and stop. Just leave loop() empty as in void loop() {}.
Thank you for your reply
I tried it and it only ran one time. This is what I have.
#include <Servo.h>
Servo servoRight;
Servo servoLeft;
  for(int n = 0; n < 2; n++);
    delay(2000);
You have a ; at the end of the for statement.
And the body of the for loop needs to be in curly brackets.
#include <Servo.h>
Servo servoRight;
Servo servoLeft;
    delay(2000);
I made that change but it still only runs once.
That worked. Thank you all!
To run the for loop 3 times it should be for(int n = 0; n < 3; Sorry, my bad.
