Hi guys
Firstly, thanks a million for all your posts. If it wasn't for these forums I probably wouldn't have come as far as i did.
Now for the problem. I have a piece of code which runs a menu and from a selection in the menu it is supposed to start a while(1) loop, however when I put in a break; based on a push button, the while(1) loop no longer read my quadrature encoder. Below is my code and the part that causes the error is on line 400. (I know there is a lot of comments and crap in the code, but being a noob it helps with remembering)
#include <Wire.h>
#include <SoftwareSerial.h>
#include <Encoder.h>
//LCD Files
#include <LCD.h>
IMPORTANT: to use the menubackend library by Alexander Brevig download it at http://www.arduino.cc/playground/uploads/Profiles/MenuBackend_1-4.zip and add the next code at line 195
void toRoot() {
setCurrent( &getRoot() );
#include <MenuBackend.h> //MenuBackend library - copyright by Alexander Brevig
const int buttonPinLeft = 9; // pin for the Up button
const int buttonPinRight = 10; // pin for the Down button
const int buttonPinEsc = 11; // pin for the Esc button
const int buttonPinEnter = 8; // pin for the Enter button
int IncDec = 0; //variable for ++ and --
int lastButtonPushed = 0;
int lastButtonEnterState = LOW; // the previous reading from the Enter input pin
int lastButtonEscState = LOW; // the previous reading from the Esc input pin
int lastButtonLeftState = LOW; // the previous reading from the Left input pin
int lastButtonRightState = LOW; // the previous reading from the Right input pin
long lastEnterDebounceTime = 0; // the last time the output pin was toggled
long lastEscDebounceTime = 0; // the last time the output pin was toggled
long lastLeftDebounceTime = 0; // the last time the output pin was toggled
long lastRightDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 250; // the debounce time
int Counter = 0; //counter to display incrementing or decrementing values
#define rxPin 0
#define txPin 1
#define I2C_ADDR 0x27 // Define I2C Address where the PCF8574A is
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
int n = 1;
const double WheelCirc = 500;
const double Pulses = 1000;
double Valv;
String toP;
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin); // set the LCD address to 0x27 for a 16 chars and 2 line display
//Menu variables
SoftwareSerial mySerial(rxPin, txPin); // RX, TX
Encoder knobLeft(2, 5);
Encoder knobRight(3, 6);
String Counter1 = "";
int lastStringLength = Counter1.length();
MenuBackend menu = MenuBackend(menuUsed,menuChanged);
//initialize menuitems
MenuItem menu1Item1 = MenuItem("Settings");
MenuItem menuItem1SubItem1 = MenuItem("Wheel Circ");
MenuItem menuItem1SubItem2 = MenuItem("Pulses");
MenuItem menuItem1SubItem3 = MenuItem("Start Depth");
MenuItem menu1Item2 = MenuItem("BH Info");
MenuItem menuItem2SubItem1 = MenuItem("Filename");
MenuItem menuItem2SubItem2 = MenuItem("Other");
//MenuItem menuItem3SubItem3 = MenuItem("Item2SubItem3");
MenuItem menu1Item3 = MenuItem("About");
MenuItem menu1Item4 = MenuItem("Start");
mySerial.begin(115200);
pinMode(buttonPinLeft, INPUT);
pinMode(buttonPinRight, INPUT);
pinMode(buttonPinEnter, INPUT);
pinMode(buttonPinEsc, INPUT);
lcd.begin(16,2);
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.print("DS - RDE");
lcd.setCursor(0,1);
lcd.print("SN: DSRDE001");
delay(3000);
lcd.setCursor(0,1);
lcd.print(" ");
//configure menu
menu.getRoot().add(menu1Item1);
menu1Item1.addRight(menu1Item2).addRight(menu1Item3).addRight(menu1Item4);
menu1Item1.add(menuItem1SubItem1).addRight(menuItem1SubItem2).addRight(menuItem1SubItem3);
menu1Item2.add(menuItem2SubItem1).addRight(menuItem2SubItem2);//.addRight(menuItem3SubItem3);
menu.toRoot();
} // setup()...
long positionLeft = -999;
long positionRight = -999;
Any advise would be welcome.
