Break?
:o
I have typed a program for stepper motor, but the break doesn’t work. Why does this happen?
int bluePin = 2;
int pinkPin = 3;
int yellowPin = 4;
int orangePin = 5;
int currentStep = 0;
void setup(){
pinMode(bluePin,OUTPUT);
pinMode(pinkPin,OUTPUT);
pinMode(yellowPin,OUTPUT);
pinMode(orangePin,OUTPUT);
digitalWrite(bluePin,LOW);
digitalWrite(pinkPin,LOW);
digitalWrite(yellowPin,LOW);
digitalWrite(orangePin,LOW);
switch(currentStep)
case 0:
digitalWrite(bluePin,HIGH);
case 1:
digitalWrite(pinkPin,HIGH);
case 2:
digitalWrite(yellowPin,HIGH);
case 3:
digitalWrite(orangePin,HIGH);
currentStep = (++currentStep < 4) ? currentStep : 0;
delay(10);
Error Message:
C:\Users\HJIS\Documents\Arduino\Realsteppermotor\Realsteppermotor.ino: In function ‘void loop()’:
Realsteppermotor:29: error: break statement not within loop or switch
Realsteppermotor:30: error: case label ‘1’ not within a switch statement
case 1:
Realsteppermotor:35: error: break statement not within loop or switch
Realsteppermotor:36: error: case label ‘2’ not within a switch statement
case 2:
Realsteppermotor:41: error: break statement not within loop or switch
Realsteppermotor:42: error: case label ‘3’ not within a switch statement
case 3:
Realsteppermotor:47: error: break statement not within loop or switch
C:\Users\HJIS\Documents\Arduino\Realsteppermotor\Realsteppermotor.ino: At global scope:
Realsteppermotor:51: error: ‘currentStep’ does not name a type
Realsteppermotor:53: error: expected constructor, destructor, or type conversion before ‘(’ token
delay(10);
Realsteppermotor:54: error: expected declaration before ‘}’ token
exit status 1
Invalid library found in \192.168.1.5\StudentsWork\00-Grade-10\Hami El Penguino\2016-2017\Hami’s Arduino\arduino-1.8.1\libraries\Realsteppermotor: \192.168.1.5\StudentsWork\00-Grade-10\Hami El Penguino\2016-2017\Hami’s Arduino\arduino-1.8.1\libraries\Realsteppermotor
Your switch is missing braces.
Your whole post is missing code tags.
What do you me by braces?
Curly brackets.
{ needs a friend }
Specifically, here:
switch(currentStep) {
case 0:
It looks like you already have the close-brace at the end of your cases...
