Breaking project into files: Confusion with Instantiated objects..
I have been breaking my project into .cpp and .h files. I am a bit confused about instances of objects.
For Instance (pun intended), If I wish to use the SoftwareSerial library in both my .ino main sketch and one of the .cpp files can I share one instance of the SoftwareSerial object? My head says yes, but I can't work out how to do it. I always end up with 'multiple definition of xyz' or ' was not declared in this scope' type errors.
**Example ** 1 instance of the SoftwareSerial object instantiated in hello.ino
// hello.ino
//INCLUDES
#include <SoftwareSerial.h>
#include "Arduino.h"
#include "world.h"
//DEFINES
//      VARIABLE		|AR. NUM.  |PIN NAME	|IC PIN	|FUNCTION
#define Soft_TXD        14          //PA1		17		Software Serial TXD
#define Soft_RXD        15          //PA2		18		Software Serial RXD
// INSTANTIATIONS
SoftwareSerial SoftSerial(Soft_RXD, Soft_TXD);    //RX, TX
	Serial.begin(9600);		// Software Serial start
	SoftSerial.print("Hello ");		// Print to softwareSerial
	world.Print("world!");			// Send to world class to print to SoftwareSerial
// world.h
#ifndef _WORLD_h
#define _WORLD_h
class worldclass
public:
	worldclass();
	void Print(String);
extern worldclass world;
#endif
// world.cpp
#include "world.h"
worldclass::worldclass() {}
void worldclass::Print(String) {
	SoftSerial.print("world");
worldclass world = worldclass();
RESULTS (which is to be expected)
world.cpp: 12:2: error: 'SoftSerial' was not declared in this scope
I can 'fix' it by creating another instance of the SoftwareSerial in the world.cpp file but then, as far as I understand it, I will have two instances in memory. That just seems wrong and I feel I should be able to use just one.
I think it may be something to do with using Extern in the .cpp file but I can not seem to get it to work with an object instance, only variables.
Pass a reference to the SoftwareSerial object (as a Stream &) into your class's constructor:
class worldclass {
  public:
    worldclass(Stream &str);
    void Print(String s);
  private:
    Stream &printStream;
worldclass::worldclass(Stream &str): printStream(str) {
void worldclass::Print(String s){
  printStream.print(s);
An example with a pointer to the class. The instance is created / deleted dynamically.
// hello.ino
#include "world.h"
Worldclass * world ;
  Serial.begin(115200);   // Software Serial start
  world = new Worldclass () ;
  Serial.print("Hello ");   // Print to Serial
  world->Print("world!");      // Send to world class to print to SoftwareSerial
  Serial.println () ;
  delete world ;
// world.h
#ifndef _WORLD_h
#define _WORLD_h
class Worldclass
public:
	Worldclass();
	void Print(String);
#endif
// world.cpp
#include "world.h"
Worldclass::Worldclass() {}
void Worldclass::Print(String) {
Thanks guys I'll give the suggestions a go when I have finished creating the rest of my latest new .cpp class.
You will want to come to a very clear understanding of what the following terms mean: define, declare, instantiate, initialize and assign along with storage classes, auto, static, extern and register and type qualifiers, const, volatile, restrict and _Atomic. It's too much to include in a response, so I'm giving you some google homework. I will be honest with you, it's not intuitive. H files typically include declarations, but not definitions, while C, CPP and INO files typically include definitions. These terms can have subtle differences between variables and functions and classes.
