Breaking up a variable into individual parts
Hello, I am trying to take a variable that reads a word and breaks it up into individual letters.
If the variable is hello, then it would break up into h e l l o.
Or if the variable reads "Turn on motor" it would break it up into multiple variables where 1 reads "Turn" the other "on" and the other "motor".
i'm using a string function called voice
and getting variable values from a blue tooth device. Where when I speak a sentence it makes that 1 variable instead of different variables for each word in the sentence.
You can directly access the bytes of the received string array, but you can do this too:
#define MAX_SIZE    20
char
    BrokenUp[MAX_SIZE];
char
    *Source = "Your mother was a hamster and your father smelled of elderberries.";
    while(!Serial);
}//setup
    int
        i;
    Serial.println(Source);
    Breakup( Source, BrokenUp, MAX_SIZE-1 );
    i=0;
    do
        Serial.println(BrokenUp[i++]);
    }while( BrokenUp[i] );
}//loop
void Breakup( char *srcString, char *destArray, int maxSize )
    int
        i=0;
    char
        chr;
    do
        chr = *srcString;
        *destArray = chr;
        *destArray++;
        *srcString++;
        *destArray = 0x00;
        i++;
    }while( chr && (i < maxSize) );
}//Breakup
