I based this on the version you gave in the very first post:
#include <math.h>
const int transistorPin = 9;
int tempPin = 0;
int tempReading;
int x;
float angle = 0;
pinMode(9, OUTPUT);
tempReading=analogRead(tempPin);//temperature reading
x=map(tempReading,150,170,1,5);//map the reading to change the frequency
Serial.println(x);
angle += 20.0/1500.0*x*PI;
float val = (exp(sin(angle)) - 0.36787944)*108.0;//the function of breathing led
Serial.println(val);
analogWrite(transistorPin, val);
delay(20);
Serial.println(x);
angle += 20.0/1500.0xPI;
delay(20);
Thank you so much!!!!! IT WORKS!!
I add a smooth code, It works flawlessly now!!!
Here is the code.
const int numReadings = 50;
int readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int average = 0;
int tempPin = 0;
int tempReading;
int x;
float angle = 0;
pinMode(9, OUTPUT);
for (int thisReading = 0; thisReading < numReadings; thisReading++)
readings[thisReading] = 0;
total= total - readings[index];
// read from the sensor:
readings[index] = analogRead(tempReading);
// add the reading to the total:
total= total + readings[index];
// advance to the next position in the array:
index = index + 1;
// if we're at the end of the array...
if (index >= numReadings)
// ...wrap around to the beginning:
index = 0;
// calculate the average:
average = total / numReadings;
// send it to the computer as ASCII digits
Serial.println(average);
delay(1);
x=map(average,155,175,1,10);//map the reading to change the frequency
angle += 20.0/2000.0*x*PI;
delay(20);
