Bricked my Mega2560 with soft reset
I have red the arduino forum from a to z but can’t find a solution.
I wanted to test if a soft reset worked and created the following sketch:
#include <SoftReset.h>
 Serial.println("Started");
 soft_restart();
void loop ()
The soft reset works GREAT. Resetting so fast that uploading a new sketch is not possible anymore. The L-led of the Arduino Mega is flickering 5 to ten times a second.
Tried to bootload the mega using an Arduino UNO as ISP. Resulting in the following error:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
I used the latest version of ArduinoISP from Github.
Hope anyone can Help?
The Wisdom of the Internet says that you are (were) using a faulty Optiboot bootloader which fouled up the watchdog timer.
You need to get the latest version of Optiboot installed, which should be safe.
(Unfortunately I have no experience with Mega2560s at present.)
Try holding RESET button with blink sketch until compile ends and AVRDUDE starts to upload... Release RESET. May take a few tries.
mrburnette:
I thought it was something as simple as that, and was about to reply accordingly, but when I searched on it, it appears to be possible to alter the watchdog fuse so that the watchdog is enabled on a short time-out and actually interrupts Optiboot, at least in older versions. Is this not so?
Tried the reset trick many times. No luck.
I also didn't use Optiboot, but default boatloader that comes with the IDE. After little research i think there is no Optiboot version voor Mega2560. At least that is stated in the Optiboot makefile.
My Mega was working correct. Only loaded a constantly resetting program. The problem is that it won't communicate anymore due to the soft reset. The problem is not bootloader specific (I think).
This is wat I get when uploading the default IDE boatloader:
C:\Arduino\arduino-1.5.8/hardware/tools/avr/bin/avrdude -CC:\Arduino\arduino-1.5.8/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v1 -PCOM10 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xD8:m -Ulfuse:w:0xFF:m
avrdude: Version 6.0.1, compiled on Apr 3 2014 at 23:12:16
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Arduino\arduino-1.5.8/hardware/tools/avr/etc/avrdude.conf"
Using Port : COM10
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81] [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82] [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98] [20]
avrdude: Recv: . [00]
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
avrdude: Send: A [41] . [84] [20]
avrdude: Send: A [41] . [85] [20]
avrdude: Send: A [41] . [86] [20]
avrdude: Send: A [41] . [87] [20]
avrdude: Send: A [41] . [89] [20]
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Send: B [42] . [00] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [00] . [00] . [00] . [00] . [01] . [00] . [10] . [00] . [00] . [04] . [00] . [00] [20]
avrdude: Send: E [45] . [05] . [08] . [d7] . [a0] . [00] [20]
avrdude: Send: P [50] [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00] [20]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00] [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00] [20]
################################## | 100% 0.06s
avrdude: Device signature = 0x000000 (retrying)
################################## | 100% 0.05s
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude: Send: Q [51] [20]
avrdude done. Thank you.
Solved the problem!
Not only Optiboot but also early versions of the Original bootloaders of the mega2526 had problems when enabling the watchdog timer.
Loading a new bootloader did't work until I found this article: Link
The problem had to do with the wiring between the Arduno as ISP and the Mega. Adding a 10uF cap did the trick.
Thanks for help Paul__B en mrburnette!
Not only Optiboot
(defensive mode) Optiboot never had a problem with Watchdog timeouts... (The previous bootloaders did, and the stk500v2 did/does, but Optiboot has always used the watchdog as part of its internal workings, and thus always included the code to manipulate it "properly." (Except for the (r1 != 0) bug.))
