I was playing with my Arduino Yun last night, and got the wireless working, I could program and upload sketches via wifi and everything was great.
When I got back to it this morning, I created a small power supply (9 volt battery, 7805 voltage regulator) to try and run the Yun away from the computer. When I plugged it in, the green power light turns on, but it won't connect to wiki. It won't create it's own network, it won't accept Ethernet connections...
I've plugged it back into the computer, so it's being powered by USB again, still nothing. I've tried plugging the Ethernet cable straight into the computer, as well as straight to the router, and I cannot access the web interface. I've searched through the routers DCHP clients table, and the Yun's IP address never appears.
When I power on the Yun, the USB light flashes once, then the green power light is solid. If I press the 32U4 reset, the RX LED will flash. If I double press the 32U4 button, the red L13 LED pulses 14 times, then the yellow RX LED flashes once.
I can still upload sketches, I've tried the YunSerialTerminal, but nothing.
My conclusion is I have somehow bricked the networking part of the Yun.
Any ideas for how to fix this? I've been searching forums and fighting with this all day, finally I have to ask. I've done what I can on my own, time to call in reinforcements!
A normal 9V battery ? That might not supply enough current to damage something. How did you use the 7805 and how did you connect it to the Arduino. If you didn't use any capacitors the 7805 behaves like an osciallator.
Peter_n:
Yes, a regular 9V. I did not use any caps the first time. I also plugged it into the 5v line for about 10 seconds, saw it wasn't working, unplugged it, double checked, then moved to Vin.
Those 10 seconds could have caused some damage. But only if you had very (very very) bad luck.
I don't know how to test what is working and what not. Sorry.
Upload the YunSerialTerminal sketch to the Arduino and then open a serial monitor with the correct baudrate 115200.
After the upload and keeping the serial monitor open, reset the linux-side with the Yun-Rst button. Do you see anything in the serial monitor after the reset?
Angelo9999:
This has happened to me as well and i have only been using 5v from computer, so you didn't damage it. The Ethernet went out first so I tried to get it working and now even though its providing its own Wi-Fi, it won't give any my devices an IP address
stevenbulfer:
YunSerialTerminal doesn't work... It sees nothing.
Either I buggered the linux side, or buggered the 32U4 chip so the two sides can no longer communicate
