Good afternoon, I've just started with this board and was playing around, it looks like I've blocked the serial port and won't connect to the PC anymore.
Is there a way to do a hard reset or wipe the code so I can reconnect?
Can you explain your problem in more detail? What is arduino board you using? What is ypur PC operation system?
I'm using the Portenta Machine Control, programing with Win 11.
The serial port seems to have locked up (or just not working properly) and is unrecognized by the PC giving a Device Descriptor Request Failed error. At this point I can no longer communicate with it and am unable to upload a new sketch.
Did this board worked on this computer before?
Yes, same PC I've been using to program it. I've only had it a few days and only been doing some initial testing in the lab, nothing else hooked up at this time.
I also tried with another PC to double check with the same result.
Unfortunately, I don't know Portenta very well.
Is there a button on the board like "Boot" to force the controller to switch to boot mode? If so, try to connect the board to USB with the button pressed.
Not that I'm aware of, I tried holding the reset, which is the only on-board button that I see.
SOLVED: Double Tapping the Reset button forces it to enter "bootloader mode", and I was able to upload a new sketch.
So I was close to the solution in post #7 ![]()
Yes, reset button as single press - a regular reset (or you do a power cycle):
Pressing reset twice - it enters bootloader:
the serial UART is gone (now an UART for bootloader - see in Device Danager or the COM port available - a different one).
Bootloader is a different UART (port). Watch the LED: if fading flashing green - the bootloader has been entered (and user UART gone, COM device disappeared for user UART, now a COM for bootloader).,
I think you need a power cycle to exit the bootloader mode (any further reset remains in bootloader mode) - if you accidently have entered bootloader mode: no need to flash again if all was OK, just exit bootloader via power cycle (but potentially wait 10sec. for repowering the board, some settings "survive" a short power outage).
