Bricked Yun - Erased bootloader!
Was going through the procedure to upgrade Linino OS, TFTP load worked fine, entered the erase command which worked then when I tried to run the copy to flash part the serial monitor froze and I couldn't enter any more commands. Now the white LED is permanently on, no response (obviously) when reset button clicked. Take it it's bricked? No other way of flashing the boot file?
Cheers
@jeeves1275, don't panic. Which board are you using? Yun, Mini, Tian, Uno wireless, Shield? Jesse
Hi Jesse
It's a yun, found a couple of similar threads and options seem to be desoldering and replacing a chip?
Have contacted seller anyway and very kindly they have sent me a replacement.
Will be reading carefully before touching it :)
Mark
@jeeves1275, okay. any details appreciated. Jesse
Do you mean details of how to possibly fix it?
If so Plan B & D here:
https://forum.arduino.cc/index.php?topic=214167.msg1571563#msg1571563
jeeves1275: Do you mean details of how to possibly fix it?
Yes. Thanks for letting use know. This will help others in the future. Jesse
