Bridge Example Now No Other Text Displays On Serial Monitor
Brand new to Arduino and messing around with the Adruino Yun. Loaded the Bridge Example to the Yun, then the ReadAnlogVoltage sketch, now cannot get anything other than the Bridge Example text on the Serial Monitor. How can I get back to Serial Print?
This is the only text that will print to the Serial Monitor now.
Unable to connect: retrying (1)...
Unable to connect: retrying (2)...
Unable to connect: retrying (3)...
Unable to connect: retrying (4)...
Unable to connect: is the sketch using the bridge?
To get back to monitoring serially you would have to go to Tools>Ports> and then select the serial port which your Yun is plugged into. It will be COM some number. This will allow you to start monitoring the serial USB data
