Odd problem. When using http://solar.local/keystore_manager_example/
I store a couple of keys. and the reload button loads them fine but if i go away from the page and back to it again it shows storage is empty.
Similar thing If I do this with a rest call. in my arduino code when i retrieve with bridge.get() I just see corrupt data
Any idea which file stores the bridge keys and if it can be deleted/replaced
thanks
mearsy25:
thanks
@mearsy25,
is not for permanent storage. It uses the cache with the webserver. The code is written in Lua. If you look on the Linux system of your Yun, you will find a file in the /tmp
directory that is create when you make a call to the bridge. It is deleted (or invalidated) at an arbitrary time (meaning know one really knows - it is a cache after all). The cache is likely invalidated when you disconnect your browser connection.
Does this help?
Jesse
