Bridge library Problem
Hello guys. Am new to arduino yun. Please i have been trying out this sample code with my arduino yun but it looks asif the bridge libraray is not allowing the code flow. especially Bridge.begin(). Please what should i do.
  Arduino Yún Bridge example
  This example for the YunShield/Yún shows how
  to use the Bridge library to access the digital and
  analog pins on the board through REST calls.
  It demonstrates how you can create your own API when
  using REST style calls through the browser.
  Possible commands created in this shetch:
  "/arduino/digital/13"     -> digitalRead(13)
  "/arduino/digital/13/1"   -> digitalWrite(13, HIGH)
  "/arduino/analog/2/123"   -> analogWrite(2, 123)
  "/arduino/analog/2"       -> analogRead(2)
  "/arduino/mode/13/input"  -> pinMode(13, INPUT)
  "/arduino/mode/13/output" -> pinMode(13, OUTPUT)
  This example code is part of the public domain
  http://www.arduino.cc/en/Tutorial/Bridge
#include <Bridge.h>
#include <BridgeServer.h>
#include <BridgeClient.h>
// Listen to the default port 5555, the Yún webserver
// will forward there all the HTTP requests you send
BridgeServer server;
  // Bridge startup
  pinMode(13, OUTPUT);
  digitalWrite(13, LOW);
  Bridge.begin();
  digitalWrite(13, HIGH);
  // Listen for incoming connection only from localhost
  // (no one from the external network could connect)
  server.listenOnLocalhost();
  server.begin();
  // Get clients coming from server
  BridgeClient client = server.accept();
  // There is a new client?
  if (client) {
    // Process request
    process(client);
    // Close connection and free resources.
    client.stop();
  delay(50); // Poll every 50ms
void process(BridgeClient client) {
  // read the command
  String command = client.readStringUntil('/');
  // is "digital" command?
  if (command == "digital") {
    digitalCommand(client);
  // is "analog" command?
  if (command == "analog") {
    analogCommand(client);
  // is "mode" command?
  if (command == "mode") {
    modeCommand(client);
void digitalCommand(BridgeClient client) {
  int pin, value;
  // Read pin number
  pin = client.parseInt();
  // If the next character is a '/' it means we have an URL
  // with a value like: "/digital/13/1"
  if (client.read() == '/') {
    value = client.parseInt();
    digitalWrite(pin, value);
    value = digitalRead(pin);
  // Send feedback to client
  client.print(F("Pin D"));
  client.print(pin);
  client.print(F(" set to "));
  client.println(value);
  // Update datastore key with the current pin value
  String key = "D";
  key += pin;
  Bridge.put(key, String(value));
void analogCommand(BridgeClient client) {
  int pin, value;
  // Read pin number
  // with a value like: "/analog/5/120"
    // Read value and execute command
    analogWrite(pin, value);
    client.print(pin);
    client.print(F(" set to analog "));
    String key = "D";
    key += pin;
    // Read analog pin
    value = analogRead(pin);
    client.print(F("Pin A"));
    client.print(pin);
    client.print(F(" reads analog "));
    String key = "A";
    key += pin;
void modeCommand(BridgeClient client) {
  int pin;
  // Read pin number
  // If the next character is not a '/' we have a malformed URL
  if (client.read() != '/') {
    client.println(F("error"));
    return;
  String mode = client.readStringUntil('\r');
  if (mode == "input") {
    pinMode(pin, INPUT);
    client.print(pin);
    client.print(F(" configured as INPUT!"));
    return;
  if (mode == "output") {
    pinMode(pin, OUTPUT);
    client.print(pin);
    client.print(F(" configured as OUTPUT!"));
    return;
  client.print(F("error: invalid mode "));
  client.print(mode);
Also posted at Bridge LIbrary not working on my arduino Yun · Issue #6479 · arduino/Arduino · GitHub
On that issue report, you said:
From my analysis of the code, i found out that it stops at the Bridge.begin();
please give details of how you determined this.
tested out with another code
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
  it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
  the correct LED pin independent of which board is used.
  If you want to know what pin the on-board LED is connected to on your Arduino model, check
  the Technical Specs of your board  at https://www.arduino.cc/en/Main/Products
  This example code is in the public domain.
  modified 8 May 2014
  by Scott Fitzgerald
  modified 2 Sep 2016
  by Arturo Guadalupi
  modified 8 Sep 2016
  by Colby Newman
// Sketch to upload pictures to Dropbox when motion is detected
#include <Bridge.h>
#include <Process.h>
// Picture process
Process picture;
// Filename
String filename;
// Pin
int pir_pin = 8;
// Path
String path = "/mnt/sda1/";
// the setup function runs once when you press reset or power the board
   delay(60000);
 Serial.println("Hello mmmmmmm");
  // Bridge
 while(!Serial);
 Serial.println("Starting bridge");
  Bridge.begin();
 Serial.println("Done");
  pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);
  Serial.println("Hello mmmmmmm");// turn the LED off by making the voltage LOW
once i added bridge.begin(), the lED doesnt come up and the serial monitor doesnt print anything
